Surface Pro 2017, Win 10 Pro x64: Explorer crash (Windows.UI.XamlHost.dll)
2018-01-04T03:56:25+00:00
Hi:
I have periodic explorer crashes on my Surface Pro 2017, Win Pro x64 (it is fully updated). The crash seems to occur periodically after a Hello Windows log-in (this occurs after the computer was sleeping rather than on a fresh boot). It seems to involve Windows.UI.XamlHost.dll based on the below.
When I look in the Event viewer I see errors like this:
Event ID 1000
Faulting application name: explorer.exe, version: 10.0.16299.125, time stamp: 0xfeba44fb
Faulting module name: Windows.UI.XamlHost.dll, version: 10.0.16299.15, time stamp: 0x00f27b8f
Exception code: 0xc0000409
Fault offset: 0x0000000000001db1
Faulting process id: 0x1880
Faulting application start time: 0x01d38282e4131af4
Faulting application path: C:\WINDOWS\explorer.exe
Faulting module path: C:\Windows\System32\Windows.UI.XamlHost.dll
Report Id: 6e835576-b35e-4d24-b6ce-331b05fa2c55
Faulting package full name:
Faulting package-relative application ID:
If I click on Start > type "view all" then click on "View all problem reports Control panel" the "Windows Explorer" "Stopped working" errors and then double click on one I would get something like this:
Source
Windows Explorer
Summary
Stopped working
Date
‎11/‎26/‎2017 10:53 AM
Status
Report sent
Description
Faulting Application Path: C:\Windows\explorer.exe
Problem signature
Problem Event Name: BEX64
Application Name: Explorer.EXE
Application Version: 10.0.16299.15
Application Timestamp: 66e02565
Fault Module Name: Windows.UI.XamlHost.dll
Fault Module Version: 10.0.16299.15
Fault Module Timestamp: 00f27b8f
Exception Offset: 0000000000001db1
Exception Code: c0000409
Exception Data: 0000000000000007
OS Version: 10.0.16299.2.0.0.256.48
Locale ID: 1033
Additional Information 1: 2eb9
Additional Information 2: 2eb9591f0e04c7cfea277e3f34d3348f
Additional Information 3: 9333
Additional Information 4: 9333781589f3ec46cd357f0fda06eea0
Extra information about the problem
Bucket ID: 15f01e3e317a50b7b6bb92d1b9fc4f7c (116455065336)
I am at a loss to understand what the problem is here. I am glad to disable Hello Windows if this would end the problem. Thanks in advance for any help on this!
[Moved from: Windows / Windows 10 / Windows Hello, lock screen & sign-in]
    2018-01-05T04:54:44+00:00
    Since this problem happens periodically, it is better to observe your computer after performing a clean boot so that we can continue troubleshooting the issue if it still persists.
    Regards.
    2018-01-04T14:32:44+00:00
    I have not made any changes (not even added any app).
    I am not sure how a clean boot will help here. It is a periodic problem, so I am not sure how I would be able to see what the source of the problem.
    2018-01-04T06:26:13+00:00
    In most cases, this error is caused by a corrupted Windows file associated with the computer system. For better assistance, we would like to know if you noticed any changes made on your computer prior to the issue?
    As an initial troubleshooting, we recommend that you perform a clean boot to remove software conflicts on your computer. For your reference, check this article on how to perform a clean boot in Windows. If the issue didn't occur after performing a clean boot, we suggest that you enable the services one by one to identify which service is causing the problem. Once you've identified the corrupted file or service, it is better to leave it disabled or uninstall it completely.
    We'll be waiting for your response.
