Display problems on some AMD Radeon video cards after installing an update
2017-12-01T02:18:06+00:00
An update was recently installed and now my AMD Radeon HD 3200 display adapter is not working as it did before. I’ve lost my preferred resolution option and the ability to use multiple monitors, and the adapter type is now reported as Microsoft Basic Display Driver. Any suggestions?
2017-12-01T02:24:28+00:00
Hi Shirlen,
We are aware of a problem that resulted in an incorrect driver update for some AMD Radeon HD 2000, 3000, and 4000 series adapters.
(Updated: 12/18/17)
If you were impacted by the incorrect driver, Windows Update KB4057291 has been released that will install a driver to restore multi-monitor display and resolution control capabilities.  Go to Start -> Settings -> Update & security, then Check for updates and install the update to resolve your issue.  You can also go to the Microsoft Update Catalog website to install the update.
(With the release of Windows Update KB4057291, it should no longer be necessary to manually delete the improper driver, as was originally recommended below.)
Follow these steps for all versions of Windows 10 to manually delete the 22.19.128.0 driver from the system and recover the recommended driver version (8.970.100.9001):
  1. Start Device Manager. To do this, press and hold (or right-click) the Start Menu icon, and then select Device Manager.
  2. Expand Display adapters, right-click the adapter that has the problem driver installed, and then select Properties.
  3. Select the Driver tab and verify driver version is 22.19.128.0.
  4. Select Uninstall Device.
  5. Check the box that says, "Delete the driver software for this device.” This step is important and will prevent the problematic driver from reinstalling in the future.
  6. The system may require a reboot at this point. Reboot if needed, then reopen Device Manager.
  7. Select any device, then click Action -> Scan for hardware changes.
  8. Recheck the driver version.  If it still reports 22.19.128.0, repeat steps 4 to 7 until the recommended driver (8.970.100.9001) is re-installed.  If this resolves your graphics problems, you can stop here.  If a different driver version is installed, follow the next step to check for the driver using Windows Update.
  9. Go to Start -> Settings -> Update & security, then Check for updates and install any available updates.
If you have further questions, feel free to reply to this thread.
256 additional answers
    2017-12-07T02:18:03+00:00
    Thank you your specific instructions for correcting this problem.  I had uninstalled drivers for two weeks but repeating it was the trick for me. Thanks again.
    Jack Byrd
    2017-12-07T18:21:36+00:00
    Thank You so much
    Steps 1 - 7 is all I needed to do and after initial reset resolution was still small but then it came right flickered and was normal again
    2017-12-07T18:48:45+00:00
    I had a similar problem with Intel HD 530 driver.  A tech helped me revert on my wife's computer, but then I had the same issue and had no back copy.  So went to Intel and found the latest driver, that did work.
  4. Deleted
