Display problems on some AMD Radeon video cards after installing an update
2017-12-01T02:18:06+00:00
An update was recently installed and now my AMD Radeon HD 3200 display adapter is not working as it did before. I’ve lost my preferred resolution option and the ability to use multiple monitors, and the adapter type is now reported as Microsoft Basic Display Driver. Any suggestions?
2017-12-01T02:24:28+00:00
Hi Shirlen,
We are aware of a problem that resulted in an incorrect driver update for some AMD Radeon HD 2000, 3000, and 4000 series adapters.
(Updated: 12/18/17)
If you were impacted by the incorrect driver, Windows Update KB4057291 has been released that will install a driver to restore multi-monitor display and resolution control capabilities.  Go to Start -> Settings -> Update & security, then Check for updates and install the update to resolve your issue.  You can also go to the Microsoft Update Catalog website to install the update.
(With the release of Windows Update KB4057291, it should no longer be necessary to manually delete the improper driver, as was originally recommended below.)
Follow these steps for all versions of Windows 10 to manually delete the 22.19.128.0 driver from the system and recover the recommended driver version (8.970.100.9001):
  1. Start Device Manager. To do this, press and hold (or right-click) the Start Menu icon, and then select Device Manager.
  2. Expand Display adapters, right-click the adapter that has the problem driver installed, and then select Properties.
  3. Select the Driver tab and verify driver version is 22.19.128.0.
  4. Select Uninstall Device.
  5. Check the box that says, "Delete the driver software for this device.” This step is important and will prevent the problematic driver from reinstalling in the future.
  6. The system may require a reboot at this point. Reboot if needed, then reopen Device Manager.
  7. Select any device, then click Action -> Scan for hardware changes.
  8. Recheck the driver version.  If it still reports 22.19.128.0, repeat steps 4 to 7 until the recommended driver (8.970.100.9001) is re-installed.  If this resolves your graphics problems, you can stop here.  If a different driver version is installed, follow the next step to check for the driver using Windows Update.
  9. Go to Start -> Settings -> Update & security, then Check for updates and install any available updates.
If you have further questions, feel free to reply to this thread.
256 additional answers
  1. Deleted
  2. Deleted
    2018-01-18T13:28:52+00:00
    my laptop has a black screen now. so how do i fix it. and will microsoft replace my laptop since they broke it
    2018-01-18T18:24:57+00:00
    please, STOP posting comments in this thread....
    There are already 22 pages in this thread! Last 2 ou 3 pages contain entries without any meaning, or describing technical problems with so few details that nobody can't answer.
    This thread had been created to document a resolution problem caused by Windows Update end of november on PC using  some AMD Radeon video cards (AMD Radeon, 2000, 3000, or 4000 series).
    This bug has "normally been corrected in december by update KB4057291.
    So:
    • if you still have a problem, and if you think this problem is related to the problem described in this thread, explain your problem, but give  all the details: version of Windows 10, which updates, which graphic card, which version of driver,  complete description of the problem (the color of the screen is not enough...)
    • if you have a problem, but if this problem is different (unfortunately, many Windows 10 users complain they have problems with wifi, with sound, with Skype...), please use an other thread,  or create a new one,
    • if you do not have any problem, but want to write something on the net, why don't you use Facebook, Twitter, or any other "social network"?
