Display problems on some AMD Radeon video cards after installing an update
2017-12-01T02:18:06+00:00
An update was recently installed and now my AMD Radeon HD 3200 display adapter is not working as it did before. I’ve lost my preferred resolution option and the ability to use multiple monitors, and the adapter type is now reported as Microsoft Basic Display Driver. Any suggestions?
2017-12-01T02:24:28+00:00
Hi Shirlen,
We are aware of a problem that resulted in an incorrect driver update for some AMD Radeon HD 2000, 3000, and 4000 series adapters.
(Updated: 12/18/17)
If you were impacted by the incorrect driver, Windows Update KB4057291 has been released that will install a driver to restore multi-monitor display and resolution control capabilities.  Go to Start -> Settings -> Update & security, then Check for updates and install the update to resolve your issue.  You can also go to the Microsoft Update Catalog website to install the update.
(With the release of Windows Update KB4057291, it should no longer be necessary to manually delete the improper driver, as was originally recommended below.)
Follow these steps for all versions of Windows 10 to manually delete the 22.19.128.0 driver from the system and recover the recommended driver version (8.970.100.9001):
  1. Start Device Manager. To do this, press and hold (or right-click) the Start Menu icon, and then select Device Manager.
  2. Expand Display adapters, right-click the adapter that has the problem driver installed, and then select Properties.
  3. Select the Driver tab and verify driver version is 22.19.128.0.
  4. Select Uninstall Device.
  5. Check the box that says, "Delete the driver software for this device.” This step is important and will prevent the problematic driver from reinstalling in the future.
  6. The system may require a reboot at this point. Reboot if needed, then reopen Device Manager.
  7. Select any device, then click Action -> Scan for hardware changes.
  8. Recheck the driver version.  If it still reports 22.19.128.0, repeat steps 4 to 7 until the recommended driver (8.970.100.9001) is re-installed.  If this resolves your graphics problems, you can stop here.  If a different driver version is installed, follow the next step to check for the driver using Windows Update.
  9. Go to Start -> Settings -> Update & security, then Check for updates and install any available updates.
If you have further questions, feel free to reply to this thread.
256 additional answers
    2017-12-24T09:08:15+00:00
    Just a thought HenryMULLER, have you tried to carry out the steps as mentioned at the beginning of this thread?
    2017-12-24T11:45:51+00:00
    Hi Ferrucio,
    according to AMD,
    http://support.amd.com/en-us/kb-articles/Pages/Win10-Driver-Support.aspx )
    your "Radeon 5000 graphics card" is supported by AMD under Windows 10 (older series, 2000, 3000,
    and 4000 are not supported by AMD under Windows 10).
    You could try to download the driver from AMD site, and see what happens.
    Probably, it will work... Perhaps, Windows Update will replace it...
    Merry Christmas
    2017-12-24T11:53:10+00:00
    Hi Henry,
    what is the exact version of your graphics card?
    If it is an ATI Radeon 2000, 3000, or 4000, I am afraid you have to use the driver provided
    by Microsoft.
    If it is a more recent card (for instance 5000), see previous entry: your card should be supported
    by AMD, and driver provided by AMD could be better than driver provided by Microsoft...
    2017-12-24T18:05:25+00:00
    I fought with this for 2 days after installing a fresh version of Windows 10. Finally ended up editing the registry using the instructions from this link.
    https://community.amd.com/thread/184967
    Can't express how frustrating this process has been. AMD and Windows have definitely disappointed me.
