I got it through NewEgg and they actually wont let me get a replacement without my original box(crazy right?) and I did a full ram test and there were no errors
Games(especially PUBG) keep constantly crashing
Hello, I recently built a new computer and whenever I play pubg it constantly crashes. I have done a lot of research and tried a lot of things but still nothing works. Mainly I get crashes saying "bad module info" or "serialization error corrupt data". Sometimes it crashes in game and whenever I try to rejoin the game crashes. or sometimes it is right on boot of the game. I have tried verifying the integrity of game files, they were fine. I have uninstalled and reinstalled the game multiple times, I have reinstalled windows, ive uninstalled and reinstalled of my memory and graphics drivers, and I have ran full tests on my memory to see if it was faulty ram or storage. All tests and things that I have tried have came up negative and I am unsure what to do. When reading online it said it could be an issue with windows game bar, or playing windowed full screen opposed to fullscreen. I have uninstalled game bar and played both yet that has done nothing. I have heard sometimes its an issue to do with the new windows update, however when I uninstall it the game doesnt work at all and windows forces a reinstall of the update. I really dont know what is going on but it has been rather frustrating because I cannot play pubg on this new computer I built for that among other things. Please help me out here.
My specs:
CPU: i7 8700k
GPU: ASUS ROG Strix 1080 ti
MOBO: ASUS z370-e gaming
RAM: 2x8GB G.Skill Trident Z RGB
2018-01-21T01:19:31+00:00 -
2018-01-21T01:21:07+00:00 Install Linux and monitor how it behaves.
2018-01-23T17:48:42+00:00 Try the following steps:
- Press "Windows Key + Pause Break" and look for "Installed memory (RAM)" and remember the value
- Click "Advanced system settings" located on the tab
- Click "Settings..." in "Advanced" tab
- Click "Advanced" once again and hit "Change..."
- Untick "Automatically manage paging file size for all drivers" if checked
- Select drive where OS is installed and tick "Custom size"
- "Initial size (MB)" should be set to the current bytes of RAM installed (eg. 8 GB of RAM makes 8000 MB, etc...)
- "Maximum size (MB)" should be set to the current maximum bytes of RAM installed (eg. 8 GB of RAM is exactly 8192 MB)
Calculations are easy, let's pick up 512 MB and multiply by 2. You get 1024, 2048 and so on until you get the value needed.
