It's simple.
Open Task Manager and scroll to the bottom.
Right click Windows Explorer and then Restart.
Problem solved.
since I installed the latest updates to windows 10, the volume icon in system tray no longer works.
The icon IS there in the system tray
hovering over the icon shows the volume level
HOWEVER, when I left click OR right click on the icon, NOTHING happens---it will not open so that I can adjust the volume level
Why do the Windows10 updates do more harm than good?
I routinely keep sound levels low until I want to listen to something---now 1 PC (Win10 home) is stuck on volume 20% and laptop ( Win10 Pro) stuck on volume 63%
How can I fix this?
THANKS
Moved from: Windows / Windows 10 / Performance & system failures / PC
It's simple.
Problem solved.
Most of the time the issue occur because the compatibility of the PC drivers. But since your getting that kind of issue, we suggest yo to check this article: Fix sounds problems. This article contains troubleshooting steps if your having issues with sounds.
We'll look forward to your response.
this is not the issue
the sound plays fine
IT IS THE system tray ICON for the sound volume which does not work any more......it will not open the sound level to adjust.
I used to click on this icon, the slide bar would come up to adjust sound level
since the Windows 10 updates were installed, the slide bar no longer comes up
the icon does not respond to a click----it is useless
I cannot adjust my volume on PC
thanks
