haiii,
I also try to give the phone to the owner but i had founded beside the Highway road , now how could i give the phone to the owner.
Hi rakeshrakesh1
In that case hand it to the autorities.
I did a hard reset on my Lumia 640. I had no idea that I needed to turn off reset protection first. When I login to my account, no devices are showing up. How else can I find myself recovery key? My phone is basically useless until I get the key. Please help!
haiii,
Hi rakeshrakesh1
I had read your text which you had kept to the customers to helping them to
login the RPRK , but I am also facing with same problem to login the RPRK.
But, the point is I didnt buy the phone and I had found the phone beside the
road and I am using it. Recently 3 times I had update the phone and its
working properly, but the 4 the time when I re set the phone it was asking
me RPRK key, I do know and I am not the owner of this phone , I didnt
stolen the phone , I had found it . So now I want to login RPRK ,
how I can login ,,, please help meee.
and dont say that give to the owner not silly answers.
Thanking you,
Hi GorlakondaRakesh
That protection was added to make sure i one loses the phone it cannot be refornated and used by some one else.
That Key is in the Microsoft account of the owner of the phone.
need a reset protection key it will not work without it after a hard start
Hi RichFollette
As explained many times before, that Key is in your Microsoft Account, the account to each the device is associated to.
Except that it is not...
