Reset protection notification
There is no rsset protection notification, the reset protection can be turn off in your Microsoft account. Also the reset key should be there.
I did a hard reset on my Lumia 640. I had no idea that I needed to turn off reset protection first. When I login to my account, no devices are showing up. How else can I find myself recovery key? My phone is basically useless until I get the key. Please help!
Enter the recovery key to turn off reset protection on this device
Hi, MithunMoulick
The question has not how you turn off the reset protection but here the reset protection Key can be fund!
Turn on
Turn on
Hi S2u2d1h9
Can you explain your post?
