install 1703 then
block all updates from MS via win+R - services.msc
works 100% for me. here on 1703 for sure much less lags that 1709 for sure.
ITS NOT SLOVE POROBLEM BUT ITS HELP USING SYSTEM WITH LESS LAGS.
there is a problem with laptops which have Intel iGPU + GTX 1050/1050Ti/1060/1070. The problem is whenever you perform some action on the OS, discrete GPU is triggered and it causes a 0.5s freeze.
Some actions, which causes the dGPU to wake up and lock up the whole system for about 0,5 seconds are:
Since the problem was OS based, it could be found on all laptop brands: ASUS, Acer, Clevo, Dell, Gigabyte, HP, Lenovo, Microsoft, MSI, Razer.
This is nearly a three-year-old bug:
Reported Models:
Effected Windows Versions:
| Version | Servicing option | Availability date | OS build | Latest revision date | |
| 1803 | Semi-Annual Channel (Targeted) | 4/30/2018 | 17134.112 | 6/12/2018 | Latest |
| 1709 | Semi-Annual Channel | 1/18/2018 | 16299.492 | 6/12/2018 | |
| 1709 | Semi-Annual Channel (Targeted) | 10/17/2017 | 16299.492 | 6/12/2018 | |
| 1703 | Semi-Annual Channel | 7/11/2017 | 15063.1155 | 6/12/2018 | |
| 1703 | Current Branch (CB) | 4/11/2017 | 15063.1155 | 6/12/2018 | |
| 1607 | Current Branch for Business (CBB) | 11/29/2016 | 14393.2312 | 6/12/2018 | |
| 1607 | Current Branch (CB) | 8/2/2016 | 14393.2312 | 6/12/2018 | |
| 1607 | Long-Term Servicing Branch (LTSB) | 8/2/2016 | 14393.2312 | 6/12/2018 | |
| 1507 (RTM) | Long-Term Servicing Branch (LTSB) | 7/29/2015 | 10240.17889 | 6/12/2018 |
Partially Fixed as of June 26, 2018.
Hi everyone,
With the latest KB4284848 the problem is partially solved. The community and I have tested the build and we can confirm that it fixes most of the freezes.
There are still some problems though. Some freezes left within the Edge browser
and File Explorer. Please post your feedback!
Fixed:
Not Fixed:
Last Update: July 15th, 2018
Yeah plugging your laptop to an external monitor will fix the issue, give "TrayPwrD3" a try if you don't want to connect an external monitor... and make TrayPwrD3 run when windows starts.
Well guys I guess I'm done here.. My little brother ended up exchanging his laptop that had a GTX 1060 for my HP OMEN model with an RX 580... I wish everyone good luck, and I really hope Microsoft fixes this issue.
Lastly I've said it before and ill say it again... IF you purchased your laptop recently and are within your 30 day return period and are fed up with this issue, return it and get the HP OMEN 17 with the RX 580 graphics, I know its hard to switch because well its AMD lol, but out of the box you get a product that performs better than a GTX 1060, CHEAPER and not to mention NO freezing issues..
Now, the RX 580 in stock speeds gets 17k in graphics which is already beating a GTX 1060.. Overclocked it jumps to 19K in graphics, which is already blowing the GTX 1060m out of the water and getting close to a GTX 1070m for a cheaper price.
Graphics driver is not approved because I'm on 17.11.4 beta drivers. Temps wile gaming 72c max(NOTE: Memory can be FURTHER overclocked, core clock as well)
https://www.3dmark.com/3dm11/12537182
I know Ive said this before but making the switch was the smartest move I made.
Thanks for your advice guy, I just returned my 2k€ Gigabyte Aero 15 and i will wait for Asus laptot with AMD CPU/GPU.
There is an Asus laptop with an AMD GPU/CPU combo... but if you don't like the AMD Ryzen mobile chips there's a lot of laptops out there with Intel CPU and the AMD RX graphic cards... remember with AMD there is NO nVidia Optimus.. so no freezing
Yeah it is kinda solution but not a perfect cure I am following the same
better something than rubbish freezing
There is no 14" AMD laptop... 2018 is coming and I'm looking at other options...
