[Partially Fixed] Intel + NVIDIA Laptop Freeze Problem
2017-06-30T16:12:20+00:00
there is a problem with laptops which have Intel iGPU + GTX 1050/1050Ti/1060/1070. The problem is whenever you perform some action on the OS, discrete GPU is triggered and it causes a 0.5s freeze.
Some actions, which causes the dGPU to wake up and lock up the whole system for about 0,5 seconds are:
  • Right click on desktop
  • Left click on battery-icon in task-bar
  • Opening Chrome-browser
  • Opening Windows Image Viewer (app + classic Foto viewer)
  • Opening system control panel
  • Provocation any animation on task bar (e.g. thumbnail-preview, ...)
  • Loading a new tab in Firefox
Since the problem was OS based, it could be found on all laptop brands: ASUS, Acer, Clevo, Dell, Gigabyte, HP, Lenovo, Microsoft, MSI, Razer.
This is nearly a three-year-old bug:
Reported Models:
  • Acer VN7-793G
  • Acer Aspire 7 - A717-71G-75MG
  • Acer Nitro 5 (AN515-51-536M)
  • Acer Nitro 5, i5 7300HQ, GTX1050 Ti
  • Acer Predator Helios 300 (PH317-51)
  • Acer Predator Trtion 700 PT715-51-70Q2
  • ASUS N580VD
  • Asus GL503VD
  • Asus GL503
  • Asus GL553VE
  • Alienware 13 R3
  • Alienware 17 R4
  • Avell Titanium G1570 Lite 4K
  • Dell 7567
  • Dell XPS L521x
  • Dell Inspiron 15 Gaming 7577
  • Dell 7510 (Early 2017)
  • Dell XPS 9560
  • Dell XPS 15 9570
  • Dell G5 with i7 8th Gen
  • Gigabyte Aero15W
  • GIGABYTE P37XV6
  • Gigabyte P35 v6
  • Gigabyte Aero 14
  • Gigabyte Aero 15
  • HP Omen 15
  • HP Omen HD630 + GTX1050
  • HP Pavilion
  • HP Pavilion Power 15-cb013ng
  • HP Pavilion Power 15-cb007nq
  • HP Spectre X360 15"
  • HP ZBook 17 G4
  • Lenovo Y720
  • Lenovo Y520
  • Lenovo W530
  • Lenovo P51 Xeon
  • Microsoft Surface Book 2 15"
  • MSI GE63VR 7RF Raider 4K
  • MSI GE62 HD4600+GXT960M
  • MSI GE62VR 6RF Apache Pro
  • MSI GE62 7RE
  • MSI GS60 2PE
  • MSI GS43VR 7RE
  • MSI GS63VR 4K
  • MSI GS73VR 7RG Stealth Pro
  • MSI GS73VR 7RF
  • MSI GS65 Stealth Thin 8RF
  • MSI GP62MVR 7RF
  • MSI GP62MVR 7RFX LEOPARD PRO
  • MSI GE72MVR 7RG
  • MSI GE73VR 7RE
  • MSI GE73VR 7RF
  • MSI GP72MVR
  • MSI GX63VR
  • MSI GE73 Raider RGB-012
  • MSI PL62 7RC (MX150)
  • Monster ABRA A7 V7.2 (Clevo)
  • Monster Tulpar T7 13.1
  • Monster Tulpar T5 V18.1 (Tongfang GK5CN6Z)
  • Razer Blade 14
  • Razer Blade 14 Late 2016
  • Razer Blade 14 2017
  • Razer Blade 2017
  • Samsung Odyssey i7 7700 + GTX 1050
  • XMG A517-dnj
  • XMG P507
Effected Windows Versions:
Version Servicing option Availability date OS build Latest revision date
1803 Semi-Annual Channel (Targeted) 4/30/2018 17134.112 6/12/2018 Latest
1709 Semi-Annual Channel 1/18/2018 16299.492 6/12/2018
1709 Semi-Annual Channel (Targeted) 10/17/2017 16299.492 6/12/2018
1703 Semi-Annual Channel 7/11/2017 15063.1155 6/12/2018
1703 Current Branch (CB) 4/11/2017 15063.1155 6/12/2018
1607 Current Branch for Business (CBB) 11/29/2016 14393.2312 6/12/2018
1607 Current Branch (CB) 8/2/2016 14393.2312 6/12/2018
1607 Long-Term Servicing Branch (LTSB) 8/2/2016 14393.2312 6/12/2018
1507 (RTM) Long-Term Servicing Branch (LTSB) 7/29/2015 10240.17889 6/12/2018
Partially Fixed as of June 26, 2018.
  • Please Update to Windows 10 1803 Build 17134.165+
  • Update Intel HD 630 driver to 24.20.100.6194+
  • Update NVIDIA Driver to 398.36+
Hi everyone,
With the latest KB4284848 the problem is partially solved. The community and I have tested the build and we can confirm that it fixes most of the freezes.
There are still some problems though. Some freezes left within the Edge browser and File Explorer. Please post your feedback!
Fixed:
  • Sometimes opening Action Centre to see the notifications causes a freeze. Fixed with Windows 10 1803 Build 17134.137.
  • Click on Safely remove hardware and it freezes! Fixed with Windows 10 1803 Build 17134.137.
  • Opening Explorer triggers dGPU without causing a freeze. Fixed with NVIDIA GeForce Driver 397.93
  • Opening some store apps like Instagram for the first time. Fixed with Windows 10 1803 Build 17134.137.
  • Turning ON Bluetooth first time after reboot freezes. Fixed with Windows 10 1803 Build 17134.165?
  • Opening Windows Image Viewer (app + classic Foto viewer) ~~>~~Fixed with Windows 10 1803 Build 17134.165?
  • Starting slideshow in MS's own PowerPoint. Fixed with Windows 10 1803 Build 17134.165?
  • First time opening Display Settings via right click triggers dGPU and causes a freeze. Fixed with Windows 10 1803 Build 17134.165?
  • Start Menu > Shut Down > Triggers dGPU and freezes. Fixed with Windows 10 1803 Build 17134.165?
Not Fixed:
  • Changing resolution > Still causing the lag sometimes.
  • Locking the session (Win + L) triggers dGPU and makes a freeze every time.
  • First time video playback with Edge triggers dGPU and causes a freeze.
Last Update: July 15th, 2018
    2017-12-11T11:49:06+00:00
    Same problem here with my new Aero15W (gtx 1060) !
    I partially solved my problem by switching off Optimus or by plugging and external monitor :O
    2017-12-11T14:16:37+00:00
    try this
    you will get much less lags for sure
    https://youtu.be/WriHktfrKJo
    Installing Microsoft Windows 10 Creators Update 1703 Download (Build 15063.0) – Available Editions from http://windowsiso.net/
    Also i did blocked all updates from MS via win+R - services.msc
    then i did installed all drivers for Intel/nvidia/chipset manually
    AND I dont have this lags anymore.
    DONT UPDATE TO 1709 OR YOU GET Freeze Problem AGAIN
    CLEAN INSTALL Microsoft Windows 10 Creators Update 1703 (Build 15063.0) AND STAY ON IT IF YOU DONT WANNA LAGS!
    2017-12-11T15:03:17+00:00
    yeah...i reduced my problem by running this TrayPwrD3 app... but thats just a walk around... we need a proper solution from microsoft....
    2017-12-11T17:21:17+00:00
    i agree. we need a patch from MS or Intel.
    for me better to use 1703 before patch comes out.
    2017-12-11T21:27:37+00:00
    Yeah plugging your laptop to an external monitor will fix the issue, give "TrayPwrD3" a try if you don't want to connect an external monitor... and make TrayPwrD3 run when windows starts.
    Well guys I guess I'm done here.. My little brother ended up exchanging his laptop that had a GTX 1060 for my HP OMEN model with an RX 580... I wish everyone good luck, and I really hope Microsoft fixes this issue.
    Lastly I've said it before and ill say it again... IF you purchased your laptop recently and are within your 30 day return period and are fed up with this issue, return it and get the HP OMEN 17 with the RX 580 graphics, I know its hard to switch because well its AMD lol, but out of the box you get a product that performs better than a GTX 1060, CHEAPER and not to mention NO freezing issues..
    Now, the RX 580 in stock speeds gets 17k in graphics which is already beating a GTX 1060.. Overclocked it jumps to 19K in graphics, which is already blowing the GTX 1060m out of the water and getting close to a GTX 1070m for a cheaper price.
    Graphics driver is not approved because I'm on 17.11.4 beta drivers. Temps wile gaming 72c max(NOTE: Memory can be FURTHER overclocked, core clock as well)
    https://www.3dmark.com/3dm11/12537182
    I know Ive said this before but making the switch was the smartest move I made.
