[Partially Fixed] Intel + NVIDIA Laptop Freeze Problem
2017-06-30T16:12:20+00:00
there is a problem with laptops which have Intel iGPU + GTX 1050/1050Ti/1060/1070. The problem is whenever you perform some action on the OS, discrete GPU is triggered and it causes a 0.5s freeze.
Some actions, which causes the dGPU to wake up and lock up the whole system for about 0,5 seconds are:
  • Right click on desktop
  • Left click on battery-icon in task-bar
  • Opening Chrome-browser
  • Opening Windows Image Viewer (app + classic Foto viewer)
  • Opening system control panel
  • Provocation any animation on task bar (e.g. thumbnail-preview, ...)
  • Loading a new tab in Firefox
Since the problem was OS based, it could be found on all laptop brands: ASUS, Acer, Clevo, Dell, Gigabyte, HP, Lenovo, Microsoft, MSI, Razer.
This is nearly a three-year-old bug:
Reported Models:
  • Acer VN7-793G
  • Acer Aspire 7 - A717-71G-75MG
  • Acer Nitro 5 (AN515-51-536M)
  • Acer Nitro 5, i5 7300HQ, GTX1050 Ti
  • Acer Predator Helios 300 (PH317-51)
  • Acer Predator Trtion 700 PT715-51-70Q2
  • ASUS N580VD
  • Asus GL503VD
  • Asus GL503
  • Asus GL553VE
  • Alienware 13 R3
  • Alienware 17 R4
  • Avell Titanium G1570 Lite 4K
  • Dell 7567
  • Dell XPS L521x
  • Dell Inspiron 15 Gaming 7577
  • Dell 7510 (Early 2017)
  • Dell XPS 9560
  • Dell XPS 15 9570
  • Dell G5 with i7 8th Gen
  • Gigabyte Aero15W
  • GIGABYTE P37XV6
  • Gigabyte P35 v6
  • Gigabyte Aero 14
  • Gigabyte Aero 15
  • HP Omen 15
  • HP Omen HD630 + GTX1050
  • HP Pavilion
  • HP Pavilion Power 15-cb013ng
  • HP Pavilion Power 15-cb007nq
  • HP Spectre X360 15"
  • HP ZBook 17 G4
  • Lenovo Y720
  • Lenovo Y520
  • Lenovo W530
  • Lenovo P51 Xeon
  • Microsoft Surface Book 2 15"
  • MSI GE63VR 7RF Raider 4K
  • MSI GE62 HD4600+GXT960M
  • MSI GE62VR 6RF Apache Pro
  • MSI GE62 7RE
  • MSI GS60 2PE
  • MSI GS43VR 7RE
  • MSI GS63VR 4K
  • MSI GS73VR 7RG Stealth Pro
  • MSI GS73VR 7RF
  • MSI GS65 Stealth Thin 8RF
  • MSI GP62MVR 7RF
  • MSI GP62MVR 7RFX LEOPARD PRO
  • MSI GE72MVR 7RG
  • MSI GE73VR 7RE
  • MSI GE73VR 7RF
  • MSI GP72MVR
  • MSI GX63VR
  • MSI GE73 Raider RGB-012
  • MSI PL62 7RC (MX150)
  • Monster ABRA A7 V7.2 (Clevo)
  • Monster Tulpar T7 13.1
  • Monster Tulpar T5 V18.1 (Tongfang GK5CN6Z)
  • Razer Blade 14
  • Razer Blade 14 Late 2016
  • Razer Blade 14 2017
  • Razer Blade 2017
  • Samsung Odyssey i7 7700 + GTX 1050
  • XMG A517-dnj
  • XMG P507
Effected Windows Versions:
Version Servicing option Availability date OS build Latest revision date
1803 Semi-Annual Channel (Targeted) 4/30/2018 17134.112 6/12/2018 Latest
1709 Semi-Annual Channel 1/18/2018 16299.492 6/12/2018
1709 Semi-Annual Channel (Targeted) 10/17/2017 16299.492 6/12/2018
1703 Semi-Annual Channel 7/11/2017 15063.1155 6/12/2018
1703 Current Branch (CB) 4/11/2017 15063.1155 6/12/2018
1607 Current Branch for Business (CBB) 11/29/2016 14393.2312 6/12/2018
1607 Current Branch (CB) 8/2/2016 14393.2312 6/12/2018
1607 Long-Term Servicing Branch (LTSB) 8/2/2016 14393.2312 6/12/2018
1507 (RTM) Long-Term Servicing Branch (LTSB) 7/29/2015 10240.17889 6/12/2018
Partially Fixed as of June 26, 2018.
  • Please Update to Windows 10 1803 Build 17134.165+
  • Update Intel HD 630 driver to 24.20.100.6194+
  • Update NVIDIA Driver to 398.36+
Hi everyone,
With the latest KB4284848 the problem is partially solved. The community and I have tested the build and we can confirm that it fixes most of the freezes.
There are still some problems though. Some freezes left within the Edge browser and File Explorer. Please post your feedback!
Fixed:
  • Sometimes opening Action Centre to see the notifications causes a freeze. Fixed with Windows 10 1803 Build 17134.137.
  • Click on Safely remove hardware and it freezes! Fixed with Windows 10 1803 Build 17134.137.
  • Opening Explorer triggers dGPU without causing a freeze. Fixed with NVIDIA GeForce Driver 397.93
  • Opening some store apps like Instagram for the first time. Fixed with Windows 10 1803 Build 17134.137.
  • Turning ON Bluetooth first time after reboot freezes. Fixed with Windows 10 1803 Build 17134.165?
  • Opening Windows Image Viewer (app + classic Foto viewer) ~~>~~Fixed with Windows 10 1803 Build 17134.165?
  • Starting slideshow in MS's own PowerPoint. Fixed with Windows 10 1803 Build 17134.165?
  • First time opening Display Settings via right click triggers dGPU and causes a freeze. Fixed with Windows 10 1803 Build 17134.165?
  • Start Menu > Shut Down > Triggers dGPU and freezes. Fixed with Windows 10 1803 Build 17134.165?
Not Fixed:
  • Changing resolution > Still causing the lag sometimes.
  • Locking the session (Win + L) triggers dGPU and makes a freeze every time.
  • First time video playback with Edge triggers dGPU and causes a freeze.
Last Update: July 15th, 2018
    2017-11-26T01:59:11+00:00
    It really works for me i install 1703 and active windows with my original key and off update install intel after nvidia driver now im using no freeze i will update this post 👍
    EDIT :
    After 1 hours using there is a %70 less than old version freezing i see.
    2017-11-26T05:28:47+00:00
    i belive next solution its investigate with UPDATE making this lags!
    FOR SURE if its 1709 or maybe its some other small fix or security update.
    I am not sure how to make it but i belive we need check and intstall one after one KB file with updates to find this point with making system laggy.
    2017-11-26T05:46:04+00:00
    I picked up the HP OMEN 17 with the RX 580, AMD's FreeSync, Thunderbolt... etc all the good stuff, and well what can I say, all issues have disappeared, not only that, the graphics have doubled in performance, (for anyone wondering the RX 580 is a hair line above the GTX 1060)
    So can you tell if the dGPU is always on in the OMEN 17? or does it switch on and off without a hiccup during windows simple operations such as right click --> display settings...
    The HP OMEN 17 by default has the Intel graphics disabled out of the box, and there is no way to enable it in bios, which is a great thing. This laptop DOES NOT have "Optimus" remember that's a feature for laptops with NVidia cards only, NOT AMD.
    There is ZERO delays or freezes(yes even if I right click and select display settings, clicking on the battery icon.. nada on the latest update in Windows 10), and yes the dGPU always stays on, even if the laptop is running on battery saver or running on battery power, and to be honest its amazing what AMD has done I'm impressed, with the laptop running on battery power, I got to say for a 17 inch notebook it gets great battery life.
    (Normal Laptop usage, watching a YouTube video, wile posting a reply here)
    @RecepBaltaş
    14 Inches? why soo small? what's your laptop model? yeah you're right, AMD Doesn't offer anything ATM, for laptops smaller than 15 inches, hopefully next year.
    @Muratkayablk
    That's what I said on my previous post...... Give Build 1607 a try, that one was the best for me.
    https://answers.microsoft.com/en-us/windows/forum/windows\_10-hardware/mobile-gtx-1060-freeze-problem/93e7004a-62b1-4211-8e37-4c136608865e?auth=1&rtAction=1511673721740&page=23
    Scroll down until you see my post.
    2017-11-26T06:07:29+00:00
    guys i need to know more info for testing
    try this and tell here what you will get lags or not
    Installing Microsoft Windows 10 Creators Update 1703 Download (Build 15063.0) – Available Editions from http://windowsiso.net/
    block all updates from MS via win+R - services.msc
    then do manually installing of all drivers for Intel/nvidia/chipset
    test system for lags and reply here because i need more info.
    if you can record video via you'r phone with build name.....
    here is video how 1703 works for me with out any lags
    i did open youtube also
    Windows 10 1703 (Build 15063.0) intel+nvidia no frezes
    2017-11-26T10:52:56+00:00
    Do you even read previous post when you comment? I guess not, let me save you the trouble ALL VERSIONS OF WINDOWS 10(1507-1709) has issues with NVidia Optimus, If you've read the previous posts it would of saved you a lot of time. Since Windows 10 was released mid 2015 it had issues with NVidia Optimus, problem was the freezing was minimal, so people barely noticed, and if you do a deeper search you WILL find post about NVidia Optimus issues with Windows 10 dating back since 2015....
