Still not all optimus related issues fixed, I think, but now all become a lot better.
In windows UI, Firefox, etc. laptop doesn't switch NVIDIA graphics at all.
and what other issues arent fixed?
there is a problem with laptops which have Intel iGPU + GTX 1050/1050Ti/1060/1070. The problem is whenever you perform some action on the OS, discrete GPU is triggered and it causes a 0.5s freeze.
Some actions, which causes the dGPU to wake up and lock up the whole system for about 0,5 seconds are:
Since the problem was OS based, it could be found on all laptop brands: ASUS, Acer, Clevo, Dell, Gigabyte, HP, Lenovo, Microsoft, MSI, Razer.
This is nearly a three-year-old bug:
Reported Models:
Effected Windows Versions:
| Version | Servicing option | Availability date | OS build | Latest revision date | |
| 1803 | Semi-Annual Channel (Targeted) | 4/30/2018 | 17134.112 | 6/12/2018 | Latest |
| 1709 | Semi-Annual Channel | 1/18/2018 | 16299.492 | 6/12/2018 | |
| 1709 | Semi-Annual Channel (Targeted) | 10/17/2017 | 16299.492 | 6/12/2018 | |
| 1703 | Semi-Annual Channel | 7/11/2017 | 15063.1155 | 6/12/2018 | |
| 1703 | Current Branch (CB) | 4/11/2017 | 15063.1155 | 6/12/2018 | |
| 1607 | Current Branch for Business (CBB) | 11/29/2016 | 14393.2312 | 6/12/2018 | |
| 1607 | Current Branch (CB) | 8/2/2016 | 14393.2312 | 6/12/2018 | |
| 1607 | Long-Term Servicing Branch (LTSB) | 8/2/2016 | 14393.2312 | 6/12/2018 | |
| 1507 (RTM) | Long-Term Servicing Branch (LTSB) | 7/29/2015 | 10240.17889 | 6/12/2018 |
Partially Fixed as of June 26, 2018.
Hi everyone,
With the latest KB4284848 the problem is partially solved. The community and I have tested the build and we can confirm that it fixes most of the freezes.
There are still some problems though. Some freezes left within the Edge browser
and File Explorer. Please post your feedback!
Fixed:
Not Fixed:
Last Update: July 15th, 2018
I think this update has solved the problem for me. Since I installed 1803, whenever I closed apps I had the micro-freeze issue. Finally, with the latest 1803 Update (Build 17134.137) this no longer seems to be the case.
Fixed for me after last night's windows update, even after a reboot.
I have problem with After Effects & Element 3D (it's not initialized correct until i shitch off Intel UHD 630 in device manager). But it can be related to video copilot support.
On previous laptop with 970M all was good.
Could you please test those:
