[Partially Fixed] Intel + NVIDIA Laptop Freeze Problem
2017-06-30T16:12:20+00:00
there is a problem with laptops which have Intel iGPU + GTX 1050/1050Ti/1060/1070. The problem is whenever you perform some action on the OS, discrete GPU is triggered and it causes a 0.5s freeze.
Some actions, which causes the dGPU to wake up and lock up the whole system for about 0,5 seconds are:
  • Right click on desktop
  • Left click on battery-icon in task-bar
  • Opening Chrome-browser
  • Opening Windows Image Viewer (app + classic Foto viewer)
  • Opening system control panel
  • Provocation any animation on task bar (e.g. thumbnail-preview, ...)
  • Loading a new tab in Firefox
Since the problem was OS based, it could be found on all laptop brands: ASUS, Acer, Clevo, Dell, Gigabyte, HP, Lenovo, Microsoft, MSI, Razer.
This is nearly a three-year-old bug:
Reported Models:
  • Acer VN7-793G
  • Acer Aspire 7 - A717-71G-75MG
  • Acer Nitro 5 (AN515-51-536M)
  • Acer Nitro 5, i5 7300HQ, GTX1050 Ti
  • Acer Predator Helios 300 (PH317-51)
  • Acer Predator Trtion 700 PT715-51-70Q2
  • ASUS N580VD
  • Asus GL503VD
  • Asus GL503
  • Asus GL553VE
  • Alienware 13 R3
  • Alienware 17 R4
  • Avell Titanium G1570 Lite 4K
  • Dell 7567
  • Dell XPS L521x
  • Dell Inspiron 15 Gaming 7577
  • Dell 7510 (Early 2017)
  • Dell XPS 9560
  • Dell XPS 15 9570
  • Dell G5 with i7 8th Gen
  • Gigabyte Aero15W
  • GIGABYTE P37XV6
  • Gigabyte P35 v6
  • Gigabyte Aero 14
  • Gigabyte Aero 15
  • HP Omen 15
  • HP Omen HD630 + GTX1050
  • HP Pavilion
  • HP Pavilion Power 15-cb013ng
  • HP Pavilion Power 15-cb007nq
  • HP Spectre X360 15"
  • HP ZBook 17 G4
  • Lenovo Y720
  • Lenovo Y520
  • Lenovo W530
  • Lenovo P51 Xeon
  • Microsoft Surface Book 2 15"
  • MSI GE63VR 7RF Raider 4K
  • MSI GE62 HD4600+GXT960M
  • MSI GE62VR 6RF Apache Pro
  • MSI GE62 7RE
  • MSI GS60 2PE
  • MSI GS43VR 7RE
  • MSI GS63VR 4K
  • MSI GS73VR 7RG Stealth Pro
  • MSI GS73VR 7RF
  • MSI GS65 Stealth Thin 8RF
  • MSI GP62MVR 7RF
  • MSI GP62MVR 7RFX LEOPARD PRO
  • MSI GE72MVR 7RG
  • MSI GE73VR 7RE
  • MSI GE73VR 7RF
  • MSI GP72MVR
  • MSI GX63VR
  • MSI GE73 Raider RGB-012
  • MSI PL62 7RC (MX150)
  • Monster ABRA A7 V7.2 (Clevo)
  • Monster Tulpar T7 13.1
  • Monster Tulpar T5 V18.1 (Tongfang GK5CN6Z)
  • Razer Blade 14
  • Razer Blade 14 Late 2016
  • Razer Blade 14 2017
  • Razer Blade 2017
  • Samsung Odyssey i7 7700 + GTX 1050
  • XMG A517-dnj
  • XMG P507
Effected Windows Versions:
Version Servicing option Availability date OS build Latest revision date
1803 Semi-Annual Channel (Targeted) 4/30/2018 17134.112 6/12/2018 Latest
1709 Semi-Annual Channel 1/18/2018 16299.492 6/12/2018
1709 Semi-Annual Channel (Targeted) 10/17/2017 16299.492 6/12/2018
1703 Semi-Annual Channel 7/11/2017 15063.1155 6/12/2018
1703 Current Branch (CB) 4/11/2017 15063.1155 6/12/2018
1607 Current Branch for Business (CBB) 11/29/2016 14393.2312 6/12/2018
1607 Current Branch (CB) 8/2/2016 14393.2312 6/12/2018
1607 Long-Term Servicing Branch (LTSB) 8/2/2016 14393.2312 6/12/2018
1507 (RTM) Long-Term Servicing Branch (LTSB) 7/29/2015 10240.17889 6/12/2018
Partially Fixed as of June 26, 2018.
  • Please Update to Windows 10 1803 Build 17134.165+
  • Update Intel HD 630 driver to 24.20.100.6194+
  • Update NVIDIA Driver to 398.36+
Hi everyone,
With the latest KB4284848 the problem is partially solved. The community and I have tested the build and we can confirm that it fixes most of the freezes.
There are still some problems though. Some freezes left within the Edge browser and File Explorer. Please post your feedback!
Fixed:
  • Sometimes opening Action Centre to see the notifications causes a freeze. Fixed with Windows 10 1803 Build 17134.137.
  • Click on Safely remove hardware and it freezes! Fixed with Windows 10 1803 Build 17134.137.
  • Opening Explorer triggers dGPU without causing a freeze. Fixed with NVIDIA GeForce Driver 397.93
  • Opening some store apps like Instagram for the first time. Fixed with Windows 10 1803 Build 17134.137.
  • Turning ON Bluetooth first time after reboot freezes. Fixed with Windows 10 1803 Build 17134.165?
  • Opening Windows Image Viewer (app + classic Foto viewer) ~~>~~Fixed with Windows 10 1803 Build 17134.165?
  • Starting slideshow in MS's own PowerPoint. Fixed with Windows 10 1803 Build 17134.165?
  • First time opening Display Settings via right click triggers dGPU and causes a freeze. Fixed with Windows 10 1803 Build 17134.165?
  • Start Menu > Shut Down > Triggers dGPU and freezes. Fixed with Windows 10 1803 Build 17134.165?
Not Fixed:
  • Changing resolution > Still causing the lag sometimes.
  • Locking the session (Win + L) triggers dGPU and makes a freeze every time.
  • First time video playback with Edge triggers dGPU and causes a freeze.
Last Update: July 15th, 2018
    2018-04-13T03:43:57+00:00
    josub01:
    Thanks for testing that out. I was also thinking of something more higher in resources when invoking the dGPU. But still weird, as those desktop triggers are not asking for much resources when switch freezing.
    About Windows 8.1:
    My 7700HQ + GTX1060 doesn't work with Windows 8.1 and I don't know how for others work... I can't do updates or install drivers. From what I see Windows 8.1 is incompatible. See below:
    As you can see I could not install the drivers and I have selected Windows 8.1 drivers from Intel and Nvidia when downloading them. Also Windows update doesn't work and you can verify what that code means: Kaby Lake is incompatible with Windows 8.1.
    2018-04-13T07:14:44+00:00
    First if you want to install nvidia driver you have to install intel’s drivers. How i can install i look youtube there are a lot of video how install intel driver and i highly recommend SDI DRIVER tool. and you can’t install last intel driver you should install old like a 6 months old driver im not sure about this. im using windows 8.1 everythings faster than win10.
    Try to use
    SDI DRIVER
    DRIVER BOOSTER
    and you can check my win 8.1 drivers works :
    https://youtu.be/1miXmjXTRKY
    https://youtu.be/EcGSxIEZZgA
    2018-04-13T08:06:46+00:00
    Anyway it doesn't matter who's blame but the problem had to be solved long time ago. My opinion is that the problem , as I already mentioned, is related to desktop version of dGPU in laptops which are turned off to save some power but it takes a bit more time to wake up or more power and some controllers are trying to prevent battery breaking and the like.
    Does anyone have a intel+Pascal laptop with mobile version of dGPU to test with Optimus view test if the dGPU is triggered?
    After I chatted with MSI (about 1 month) and did some tests that they asked me to, I ended up with sending my laptop to their head service center in Poland for investigation. Will come later with some information about when I get my laptop back.
    I sent them the links to this and Intel threads and told them that there are many people with MSI laptops that have issue so they definitely should know about.
    P.S. I understand that my English is bad, I did my best to explain my thoughts)))
    2018-04-13T08:57:58+00:00
    Also I have one more strange thing. When I disable the intel gpu the dGPU is also turning off and the laptop have no more gpus. Does anyone experience the same?
    2018-04-13T10:09:16+00:00
    What's a temporary workaround for this problem?
    The TrayPwD3 program doesn't seem to work for me either.
    I'm getting constant frame stutters in game.
    Help would be appreciated.
