Hi all here,
i got a BIOS Update on my HP Omen 15-ce004ng, i7-7700HQ and GTX 1050.
After the BIOS update, the freeze and the lags got a lot better. Only in a few cases is it annoying.
I will test it further.
Sorry for my bad English :)
there is a problem with laptops which have Intel iGPU + GTX 1050/1050Ti/1060/1070. The problem is whenever you perform some action on the OS, discrete GPU is triggered and it causes a 0.5s freeze.
Some actions, which causes the dGPU to wake up and lock up the whole system for about 0,5 seconds are:
Since the problem was OS based, it could be found on all laptop brands: ASUS, Acer, Clevo, Dell, Gigabyte, HP, Lenovo, Microsoft, MSI, Razer.
This is nearly a three-year-old bug:
Reported Models:
Effected Windows Versions:
| Version | Servicing option | Availability date | OS build | Latest revision date | |
| 1803 | Semi-Annual Channel (Targeted) | 4/30/2018 | 17134.112 | 6/12/2018 | Latest |
| 1709 | Semi-Annual Channel | 1/18/2018 | 16299.492 | 6/12/2018 | |
| 1709 | Semi-Annual Channel (Targeted) | 10/17/2017 | 16299.492 | 6/12/2018 | |
| 1703 | Semi-Annual Channel | 7/11/2017 | 15063.1155 | 6/12/2018 | |
| 1703 | Current Branch (CB) | 4/11/2017 | 15063.1155 | 6/12/2018 | |
| 1607 | Current Branch for Business (CBB) | 11/29/2016 | 14393.2312 | 6/12/2018 | |
| 1607 | Current Branch (CB) | 8/2/2016 | 14393.2312 | 6/12/2018 | |
| 1607 | Long-Term Servicing Branch (LTSB) | 8/2/2016 | 14393.2312 | 6/12/2018 | |
| 1507 (RTM) | Long-Term Servicing Branch (LTSB) | 7/29/2015 | 10240.17889 | 6/12/2018 |
Partially Fixed as of June 26, 2018.
Hi everyone,
With the latest KB4284848 the problem is partially solved. The community and I have tested the build and we can confirm that it fixes most of the freezes.
There are still some problems though. Some freezes left within the Edge browser
and File Explorer. Please post your feedback!
Fixed:
Not Fixed:
Last Update: July 15th, 2018
Hi all here,
did anyone tried if the problem has been solved in the new Windows 10 Redstone 4 Insider Preview [17093.1000]?
Dear Microsoft Team,
Requesting you to please prioritise the Issue and assign a resource to look into this and resolve it once and for all.
Please do revert, when can we expect a reply with solution instead of workaround for this issue.
17101.1000 problem is gone for me. There is no lag or freeze. intel gpu works smoothly.
What about the nvidia or amd if you have one? I was just reading about Redstone 4 and it looks promising on support for duo graphics systems.
