Hello Recep;
I cant follow anymore ur post which you created on intel forums.
I bought Msi GS63VR 7RF. And i have same problems. Is it just problems about MSI or also other marks has similar problems ?
Hope ur posts will bring some results.
there is a problem with laptops which have Intel iGPU + GTX 1050/1050Ti/1060/1070. The problem is whenever you perform some action on the OS, discrete GPU is triggered and it causes a 0.5s freeze.
Some actions, which causes the dGPU to wake up and lock up the whole system for about 0,5 seconds are:
Since the problem was OS based, it could be found on all laptop brands: ASUS, Acer, Clevo, Dell, Gigabyte, HP, Lenovo, Microsoft, MSI, Razer.
This is nearly a three-year-old bug:
Reported Models:
Effected Windows Versions:
| Version | Servicing option | Availability date | OS build | Latest revision date | |
| 1803 | Semi-Annual Channel (Targeted) | 4/30/2018 | 17134.112 | 6/12/2018 | Latest |
| 1709 | Semi-Annual Channel | 1/18/2018 | 16299.492 | 6/12/2018 | |
| 1709 | Semi-Annual Channel (Targeted) | 10/17/2017 | 16299.492 | 6/12/2018 | |
| 1703 | Semi-Annual Channel | 7/11/2017 | 15063.1155 | 6/12/2018 | |
| 1703 | Current Branch (CB) | 4/11/2017 | 15063.1155 | 6/12/2018 | |
| 1607 | Current Branch for Business (CBB) | 11/29/2016 | 14393.2312 | 6/12/2018 | |
| 1607 | Current Branch (CB) | 8/2/2016 | 14393.2312 | 6/12/2018 | |
| 1607 | Long-Term Servicing Branch (LTSB) | 8/2/2016 | 14393.2312 | 6/12/2018 | |
| 1507 (RTM) | Long-Term Servicing Branch (LTSB) | 7/29/2015 | 10240.17889 | 6/12/2018 |
Partially Fixed as of June 26, 2018.
Hi everyone,
With the latest KB4284848 the problem is partially solved. The community and I have tested the build and we can confirm that it fixes most of the freezes.
There are still some problems though. Some freezes left within the Edge browser
and File Explorer. Please post your feedback!
Fixed:
Not Fixed:
Last Update: July 15th, 2018
Hello Recep;
Last time I checked, yesterday, maybe 2 days ago, I'm not completely sure, this complaints thread had 49 pages, now it's down to 45. Who's deleting people's complaints and why? How many times has this thread been edited before this?!
First post is very clear on this:
The problem can be found on all laptop brands: ASUS, Acer, Clevo, Dell, Gigabyte, HP, Lenovo, MSI, Razer.
It was me deleting some of my old posts.
Ok guys and gals! We got an ETA!
Hello all,
I believe we have root caused the issue and are testing various potential fixes, one looking promising so far. This happens often though in fixing bugs, we'll attempt to check in and hopefully it won't cause other issues or break when combined with other code fixes. It is a step in the right direction though and I thought I'd share progress. If all goes well, we could be looking at a fix in our March/April driver depending on any complications and perhaps a Beta if I can get one out sooner. I'll keep the updates coming as they're available.
.:Bryce:.
