Wireless Xbox One controller requires PIN for Windows 10.
2017-08-22T14:48:00+00:00
I cant connect my xbox wireless controller to my PC with Bluetooth because Windows 10 requires a PIN.
The controller is discovered by Bluetooth under add new device and it recognizes that it is an Xbox Wireless Controller. However when I hit the connect button it asks for a PIN without the option to not use one. As far as I know the Xbox Controller does not have a PIN. Currently the official xbox troubleshoot guide says to connect with USB. Not only do I not want to use a wire for my wireless controller but I never received one with it.
Please note that this is not an issue with the controller. It connects to a Xbox console and MacBook without any issues. I just cant connect to Windows 10. What I am looking for is a PIN that works, a way to remove the PIN requirement, or some other fix that doesn't involve buying something else as a work around.
[Moved from: Windows / Windows 10 / Devices & drivers]
2017-08-26T00:26:54+00:00
You will be asked for a PIN when connecting your wireless Xbox One controller via Bluetooth on Windows 10 if your Bluetooth drivers are not updated. It is also possible that you have to reset the controller to remove the PIN. To resolve your concern, restart your controller by following the steps below:
  1. Power off the controller by pressing and holding the Xbox button  on the controller for 6 seconds.
  2. Press the Xbox button  again to power it back on.
  3. Connect your Xbox Wireless Controller to your PC using a USB cable or the Xbox Wireless Adapter for Windows.
You can also update your Bluetooth drivers by following the steps on this link.
Keep us updated with the results after performing the suggested solutions above.
2017-11-22T00:14:06+00:00
Thank you for your response. The Xbox Wireless Adapter for Windows can only be used to connect an Xbox Wireless Controller to your Windows 10 PC. Miracast has a different wireless adapter which is used to stream on the TV. This device is similar to the Microsoft Wireless Display Adapter.
Since you are trying to use an Xbox Wireless Controller, we recommend that you use the Xbox Wireless Adapter for a stable connection to your PC.
Should you have any other queries, you can contact us anytime.
42 additional answers
    2017-08-22T16:25:12+00:00
    2017-08-22T16:41:11+00:00
    This has to do with Windows 10.
    2017-10-21T15:43:27+00:00
    I am having the same problem
    I tried to restart the controller and update the Bluetooth but it's already updated
    there's nothing wrong with the computer because I had another controller and it was working but when I connected another one I wanted to pair it, at first the controller had not a name and I clicked on it anyways and then the name changed to "Xbox wireless controller" and then it asked for a PIN code and now I restarted both of the controllers and neither the old controller nor the new controller works
    **UPDATE**
    I updated the laptop to the latest version and everything is fine
