I ran through the basic troubleshooter you mentioned, not really helpful.
This is what I have done (and can reproduce it)
- Reboot windows 10.
- Controller works fine
- Put computer to SLEEP
4 Wake from sleep
- Controller turns on, sync, working, for 5 second. Controller turns OFF
- LOG OUT
- LOG IN
8 COntroller works as #2 above
9 RInse repeat
100% reproducible. How can I help further? Its infurating.
I have also gone into device manager and DELETED my adapter
I even bought ANOTHER adapter and same issue.
SAme issue with 2 xbox one controllers (XBOX Elite and Regular, NOT the S)
