The same would happen to me, but it would be that it would work for a couple of days or maybe a week. But if I was to stop using for a couple of days and leave it still plugged into my computer, it would not light up or connect with the wireless controller if I was to start using it again a couple of days later or a week later. I would have to unplug it and plug it back in or even uninstall the driver for the adapter and reinstall it to fix it. So right now I just uninstall the driver for the adapter and stop using the controller for now until maybe when the creator update comes out. Maybe by that time, there will be a new update for the adapter driver to fix the issue.
Xbox One Wireless controller keeps disconnecting
Hello.
I recently bought a Xbox One Wireless controller with the PC wireless adapter.
The problem is... after I logon into Windows 10 the controller connects fine ONE TIME, then, after turning it off and then turning it on again, the controller connects (light stay still) for about 1 or 2 seconds and then the controller turns off again, I even can use it in those 1 or 2 seconds, showing that it successfully connected, but then it disconnects. The problem is only solved after I logoff and login again into Windows (don't need to do a full reboot).
My wired Xbox 360 controller works like a charm. Why do the next gen controller of Microsoft doesn't work well with a system developed by the same company? When I google it, it's problems all around. And judging by the behavior, it's a driver problem, not hardware, cause if it was a defective unit a simple logoff-login wouldn't fix it (and lots of other people wouldn't have similar problems).
Thanks in advance.
EDIT: link to the same post on the Feedback Hub: https://aka.ms/Phrwta so anyone passing by can easily enter and give a vote to the problem. Thanks!
2017-01-30T03:16:35+00:00 -
2017-01-30T18:27:00+00:00 Hi Gabriel,
To isolate the problem with your Xbox One wireless controller. Here is a link on how to troubleshoot your Xbox One controller for Windows.
Let us know how it goes.
Regards.
2017-01-30T22:15:52+00:00 Where is the link? There is no link to click (using EDGE).
I have the EXACT same problem.
A simple LOG OFF and LOG back in fixes it.
2017-01-30T23:21:31+00:00 Hello.
Thanks in advance.
This is driving me crazy. It happens with 2 different controllers (XBOX ONE and XBOX ONE PRO) and I even bought a SECOND adapter - same thing
I have tried
USB2
USB3
No matter what it happens
Asus Z77
Intel 3770k
NVIDIA 1080
Latest windows (NOT insider)
2017-01-31T17:23:47+00:00 Thank you for your response, here is a link on how to troubleshoot your Xbox One controller for Windows.
Keep us in the loop.
Regards.
