Vcruntime140.dll was not found
2016-09-10T08:12:27+00:00
how can I reinstall VCRuntime140.dll on windows 10
2017-06-05T05:10:53+00:00
This is the link that you want (need) as of 6/5/17, choose between the 32bit (x86) or the 64bit (x64) or just install both if you have a 64bit (x64) based system.
Hint: The 32 bit is the most commonly used for app and program development as it will run on both 32bit and 64bit PC's.
https://www.microsoft.com/en-us/download/details.aspx?id=52685
Good Luck,
-Richard
2017-12-17T09:25:51+00:00
You need to install the Microsoft Visual C++ 2015 Redistributable Update 3 RC from the link supplied in the marked as answer reply to this thread, the 32bit version download and install of the data link library will be the most likely one that you will need, even if you are using a 64bit system, however, if the app that needs the file to run was developed for a 64bit OS only then you will need the 64bit version. You can install both versions on a 64bit system as a 64bit system will run both 32bit and 64bit apps and/or programs.
Here is the link again, for your convenience.
Let us know how it goes,
-Richard
135 additional answers
    2018-08-04T15:16:48+00:00
    Well guess what, they are using a Microsoft product, they should expect that it will be a painful experience and nothing will work, or guaranteed to break and cost them pain, frustration and time wasted. The good news is that Microsoft now packages games with Windows, if they work, they can spend their time playing those and sign up to pay Microsoft money for the things Microsoft wants to sell them and forget about their business and actual goals.
    2018-08-05T01:37:30+00:00
    This is a community forum were users donate their time and knowledge to help other users, free of charge. We, as such, are not compensated in anyway, whatsoever. The vast majority of responders here are not Microsoft employee's, (some are however subcontractors).
    If you wish to interact with Microsoft Corp. employee's directly I would suggest using the Feedback Hub instead of this forum site.
    Your choice though, of course.
    https://answers.microsoft.com/en-us/windows/forum/windows_10-windows_install/windows-10-creators-update-and-the-feedback-hub/3497864b-6d55-45bd-834c-4be5edef08a1
    Regards,
    -Richard
    2018-08-10T21:48:01+00:00
    necesito restaurar ese programa gracias
