"DLL" files are already provided to you with the software. Sometimes you get the error of a particular DLL file missing on your computer screen because the files get deleted or removed by the anti-virus while scanning.
VCRuntime140.dll is one of them. We can solve this error manually, but remember that you have to paste the missing DLL file exactly to the location where it was before.
You can also try these 3 tasks to solve the DLL error.
- You can perform virus/malware scan of your entire system that can also fix the DLL error.
- You can also reinstall the entire software/program that uses the DLL file.
- Sometimes the DLL file get deleted accidently so you can restore it from the Recycle Bin.
If these don't work then try the manual process. Go to the link given below and follow the steps to tackle the vcruntime140.dll file.
https://techanswersweb.wordpress.com/2017/06/05/how-to-deal-with-vcruntime140-dll-error/
