Vcruntime140.dll was not found
2016-09-10T08:12:27+00:00
how can I reinstall VCRuntime140.dll on windows 10
2017-06-05T05:10:53+00:00
This is the link that you want (need) as of 6/5/17, choose between the 32bit (x86) or the 64bit (x64) or just install both if you have a 64bit (x64) based system.
Hint: The 32 bit is the most commonly used for app and program development as it will run on both 32bit and 64bit PC's.
https://www.microsoft.com/en-us/download/details.aspx?id=52685
Good Luck,
-Richard
2017-12-17T09:25:51+00:00
You need to install the Microsoft Visual C++ 2015 Redistributable Update 3 RC from the link supplied in the marked as answer reply to this thread, the 32bit version download and install of the data link library will be the most likely one that you will need, even if you are using a 64bit system, however, if the app that needs the file to run was developed for a 64bit OS only then you will need the 64bit version. You can install both versions on a 64bit system as a 64bit system will run both 32bit and 64bit apps and/or programs.
Here is the link again, for your convenience.
Let us know how it goes,
-Richard
135 additional answers
    2017-10-11T17:28:59+00:00
    where did u move this to?
    The address bar indicates that it was moved to Windows / Windows 10 / Install, upgrade, & activate / PC.
    What category location it was moved here from, I do not know.
    2017-10-15T16:24:27+00:00
    Tried both, none solves the problem. Any more ideas?
    2017-10-15T18:38:38+00:00
    If this is on a HP device refer to the reply of neilpzz on September 28, 2017 on page 6 of this thread.
    More info from HP:
    HP 3D DriveGuard Error Message After Update to Windows 10 Creators Update
    Let us know how it goes.
    -Richard
