Vcruntime140.dll was not found
2016-09-10T08:12:27+00:00
how can I reinstall VCRuntime140.dll on windows 10
2017-06-05T05:10:53+00:00
This is the link that you want (need) as of 6/5/17, choose between the 32bit (x86) or the 64bit (x64) or just install both if you have a 64bit (x64) based system.
Hint: The 32 bit is the most commonly used for app and program development as it will run on both 32bit and 64bit PC's.
https://www.microsoft.com/en-us/download/details.aspx?id=52685
Good Luck,
-Richard
2017-12-17T09:25:51+00:00
You need to install the Microsoft Visual C++ 2015 Redistributable Update 3 RC from the link supplied in the marked as answer reply to this thread, the 32bit version download and install of the data link library will be the most likely one that you will need, even if you are using a 64bit system, however, if the app that needs the file to run was developed for a 64bit OS only then you will need the 64bit version. You can install both versions on a 64bit system as a 64bit system will run both 32bit and 64bit apps and/or programs.
Here is the link again, for your convenience.
Let us know how it goes,
-Richard
135 additional answers
  1. Neil D 34,285 Reputation points Volunteer Moderator
    2017-10-03T21:00:55+00:00
    Have you read previous answers. Taken from a previous post of mine.
    If you have an HP then it is part of HP software 3D Guard that protects your device hard drive against shock. You need to uninstall the current version and install the latest.
    http://ftp.hp.com/pub/softpaq/sp81001-81500/sp81142.exe
    2017-10-05T12:24:02+00:00
    This link goes to a Microsoft ad. ///////\
  3. Neil D 34,285 Reputation points Volunteer Moderator
    2017-10-05T14:26:33+00:00
    The link goes to the download page with an ad at the top.
    But if you have a HP you might want to try this.
