Hi Luke,
See my reply post of August 10th on page 4 of this thread, it contains the information that you need.
Let us know how it goes and Good Luck.
-Richard
Thx @RichardEiler i will reply with my answer asap. Ok i read the post and it rocked but can you explain how only the 2015 package will help when its 2017 and why would i need just one package from the past and not all the past ones. Sorry for my bad punctuattion
and spelling im on tiny tablet this time.however,plz get back to me asap. ok i tried it it says that its already in my computer so it cannot install but if its in my computer WHY IS MY COMPUTER HAVING THIS PROBLEM.ok i deleted the old one i figured it out
for some reason that package is on my computer,BUT ITS x84-32bit, MY OPRATING SYSTEM IS x64-64BIT,I THINK AFTER 2 YEARS ITS GONNA WORK RICHARD YOU RICH WITH AWESOMNESS AND KNOWLEDGE.ITS SAYING ANOTHER ONE OF THE SAME FILE IS STILL IN MY COMPUTER -_-.ok i didnt
have time to finish last night and im finishing now hope this works :),um ok i deleted the vc_redist.x64 2015 versions located in my control panel remove option and in my file explorer and it still says anither version of it is in my computer!? ok so now im
deleting and reinstalling all my old vc_redist packages why am i doing that,well because i figured out why all ive been having this problem all but like one of my vc_redist packages is oh idk 32FRIKIN BIT I HAVE 64BIT OPERATING SYSTEM YEASH THANKS SO MUCH.ok
moment of truth lets test the baby.welp didnt work i officially give up im crying ive been trying to do this os long i come so close doesent work great just great thx alot world.
