Vcruntime140.dll was not found
2016-09-10T08:12:27+00:00
how can I reinstall VCRuntime140.dll on windows 10
2017-06-05T05:10:53+00:00
This is the link that you want (need) as of 6/5/17, choose between the 32bit (x86) or the 64bit (x64) or just install both if you have a 64bit (x64) based system.
Hint: The 32 bit is the most commonly used for app and program development as it will run on both 32bit and 64bit PC's.
https://www.microsoft.com/en-us/download/details.aspx?id=52685
Good Luck,
-Richard
2017-12-17T09:25:51+00:00
You need to install the Microsoft Visual C++ 2015 Redistributable Update 3 RC from the link supplied in the marked as answer reply to this thread, the 32bit version download and install of the data link library will be the most likely one that you will need, even if you are using a 64bit system, however, if the app that needs the file to run was developed for a 64bit OS only then you will need the 64bit version. You can install both versions on a 64bit system as a 64bit system will run both 32bit and 64bit apps and/or programs.
Here is the link again, for your convenience.
Let us know how it goes,
-Richard
135 additional answers
    2017-08-11T13:48:32+00:00
    I did install both 86 and 64 on my win 10 / 64 bit. Kind of guessed at the solution you posit here. My machine is working fine. This forum is a worthwhile help. Thanks.
    2017-08-11T20:34:40+00:00
    I have been having this problem for years on end,while trying to download exploits and related things.for things such as,online server games-third party apps,etc.but no matter what i do i get the same error message vcruntime140.dll is either missing from your computer or the file is corrupt/unusable.
    so the big question here, HOW DO I FIX THIS PROPERLY AND FULLY SO THIS WONT KEEP HAPPENING.
    2017-08-12T02:41:45+00:00
    You're welcome, glad that I could be of help.
    -Richard
