Display Dock for Continuum (Firmware)
2016-03-07T07:49:55+00:00
Display Dock doesn't appear in Gadgets on my Lumia 950, and I can't updated the dock with latest firmware. How do I fix this?
    2016-12-13T15:04:29+00:00
    Hi Conorn
    Nothing has changed other than Microsoft has let it out of the box again. It is still the same version it was months ago!
    2017-02-20T20:38:30+00:00
    Gadgets : 4.4.1609.2000 4.3.1608.28000
    OS Build : 10.0.14393.726
    Gadgets app doesn't work already from when I received the Anniversary update, so I can't update the dock and it doesn't recognize any device.
    Are you thinking to fix this already ?
    2017-02-21T07:16:48+00:00
    The gadgets app works fine on my Lumia 950xl running the same Gadgets version and OS Build Version, in fact it has done ever since the current version of Gadgets was released.
    Hope this helps
    Ewan
    2017-02-21T07:47:13+00:00
    @ 92Solutions
    I think you have other issues because like Ewan I also do not have any issues
    Gadgets app version 4.4.1609.2000 4.3.1608.28000 is also working fine on a 950XL with the fast ring 15031 build.
    2017-05-07T14:51:31+00:00
    I have a Microsoft 500 BLOCK that needs to be upgraded.......I am running a new AlcATel IDOL 4S and I also have the wireless hookup. This is what I have found: I RUN MY PHONE WITH THE mICROSOFT WIRELESS continuum DEVICE,,,,,,,,,AND AT SAME TIME I HOOK UP THE WIRED 500 (BUT NOT WITH THE HDMI CONNECTION), AND I CAN THEN HOOK UP ANY PORTABLE usb DRIVE TO THE MICROSOFT 500 BLOCK, AND CHARGE MY PHONE AT THE SAME TIME....AND VIEW THE FILES WIRELESSLY ON THE SCREEN.
    uSING THE mICROSOFT 500 CONTINUUM DEVICE WITHOUT THE UNAVAILABLE UPGRADE OF THE DEVICE DOES NOT ALLOW ME TO SEE ALL OF THE TV SCREEN. THAT IS WHY I HAVE HAD TO EXPERIMENT TO FIND THE ABOVE WORK-A-ROUND............GO TO WORK MICROSOFT, AND UPGRADE THE 500 CONTINUUM BLOCK (WITH AN UPGRADE I CAN UPLOAD ON MY ALCATEL IDOL 4S)
