Display Dock for Continuum (Firmware)
2016-03-07T07:49:55+00:00
Display Dock doesn't appear in Gadgets on my Lumia 950, and I can't updated the dock with latest firmware. How do I fix this?
    2016-03-07T22:31:38+00:00
    On my Lumia 950Xl the redstone build 1004 is running as well. And now - after three months - my display dock arrives and I can't update the firmware. The gadget-app don't show the HD-500.
    2016-03-07T19:55:10+00:00
    This problem is mentioned in the feedback app actually severall times allready.
    I noticed this problem with the first redstone insider build for the 950 that I have over here. Now running with the 1004 redstone build the problem still exists
     mrTablet63is right with saying that we can't update the firmware on the HD-500 display dock due this error/problem
    2016-03-07T13:41:36+00:00
    Thank you for posting your query on Microsoft community. I regret the inconvenience caused to you. Let me help you.
    Display Dock device to connect next-generation Lumia 950 and Lumia 950XL smartphones with full-sized keyboards and large desktop displays, with seven different ports, appears like your typical, lowly dock. However, Microsoft marketers have pointed out that the dock can turn a powerful Lumia smartphone into a near-fully functioning PC.
    • In order to investigate the issue, Please let us which version of Windows 10 and build you are using on the phone.
     Do update us with the above details, we are glad to assist you further.
