zune offline firmware update
2016-03-10T06:42:25+00:00
for all you guys that need to restore your zune. ya need to do a 20 gigs partition with win 7 ultimate updated +.net framework all versions installed + zune software 4.8 + firmware update installing msi (x86 or x64)  :
http://fichiers.touslesdrivers.com/30841/Zune-Firmware-x86.msi
http://fichiers.touslesdrivers.com/30842/Zune-Firmware-x64.msi
this will be restoring all zune models ;D
update 04/06/2016 : a little link with allmost all zune hd apps
https://onedrive.live.com/?authkey=%21AN5Z2WThVUIaULs&cid=09C19EF1AFEDDE39&id=9C19EF1AFEDDE39%2144932&parId=9C19EF1AFEDDE39%2144933&action=locate
update 04/09/2016 :
zune software download
https://www.microsoft.com/es-mx/download/details.aspx?id=27163
  1. make a 20 gigs partition on  hdd
  2. .install win 7 ultimate edition
  3. install net framework 3.5.1 + all win 7 updates.
4 . install zune software 4.8 and zune firmware msi- (x86 obviously in 32 bit or -x64 in 64 bit system)
  1. plug the zune to computer. it will be downloading the last version of zune drivers
  2. start zune software and update screen will be displaying in main zune softs screen . thats it.
when you double click zune  firmware-x86 or x64 the msi package install FW .cab files in: C:\ProgramData\Microsoft\Zune\Firmware Updates
and firmware update.xml emulates online mode for restoring ;D
EDIT: FIRMWARE OFFLINE RECOVERY WILL WORK ONLY ON WIN 7.
Windows for home | Other | Apps
    2016-08-03T16:18:50+00:00
    Im at work right now so  will look later about the abyss error but your host file remove the '#'  for the line were you have 127... Resource... Because that symbol means its commented out and therefore wont apply
    2016-08-03T16:35:13+00:00
    this is the very same way my hosts file looks like:
    Copyright (c) 1993-2009 Microsoft Corp.
    This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
    This file contains the mappings of IP addresses to host names. Each
    entry should be kept on an individual line. The IP address should
    be placed in the first column followed by the corresponding host name.
    The IP address and the host name should be separated by at least one
    space.
    Additionally, comments (such as these) may be inserted on individual
    lines or following the machine name denoted by a '#' symbol.
    For example:
         102.54.94.97     rhino.acme.com          # source server
          38.25.63.10     x.acme.com              # x client host
    localhost name resolution is handled within DNS itself.
    127.0.0.1       localhost
    ::1             localhost
    unchecky_begin
    These rules were added by the Unchecky program in order to block advertising software modules
    0.0.0.0 0.0.0.0 # fix for traceroute and netstat display anomaly
    0.0.0.0 tracking.opencandy.com.s3.amazonaws.com
    0.0.0.0 media.opencandy.com
    0.0.0.0 cdn.opencandy.com
    0.0.0.0 api.opencandy.com
    0.0.0.0 api.recommendedsw.com
    0.0.0.0 installer.betterinstaller.com
    0.0.0.0 installer.filebulldog.com
    0.0.0.0 d3oxtn1x3b8d7i.cloudfront.net
    0.0.0.0 inno.bisrv.com
    0.0.0.0 nsis.bisrv.com
    0.0.0.0 cdn.file2desktop.com
    0.0.0.0 cdn.goateastcach.us
    0.0.0.0 cdn.guttastatdk.us
    0.0.0.0 cdn.inskinmedia.com
    0.0.0.0 cdn.insta.oibundles2.com
    0.0.0.0 cdn.insta.playbryte.com
    0.0.0.0 cdn.llogetfastcach.us
    0.0.0.0 cdn.montiera.com
    0.0.0.0 cdn.msdwnld.com
    0.0.0.0 cdn.mypcbackup.com
    0.0.0.0 cdn.ppdownload.com
    0.0.0.0 cdn.riceateastcach.us
    0.0.0.0 cdn.shyapotato.us
    0.0.0.0 cdn.solimba.com
    0.0.0.0 cdn.tuto4pc.com
    0.0.0.0 cdn.appround.biz
    0.0.0.0 c
    dn.bigspeedpro.com
    0.0.0.0 cdn.bispd.com
    0.0.0.0 cdn.bisrv.com
    0.0.0.0 cdn.cdndp.com
    0.0.0.0 cdn.download.sweetpacks.com
    0.0.0.0 cdn.dpdownload.com
    0.0.0.0 cdn.visualbee.net
    unchecky_end
    127.0.0.1 resources.zune.net
    if ya notice 127... resources its not between ::1 . localhost and # unchecky begin
    as i said before, dumb proof  .... offline zune eruil edit.rar contains inside hosts file ( just copy and paste in c: windows / system32 / drivers/ etc as administrators. copy and paste abyss web server folder to c: and abyss.conf
    <root>
    C:\Abyss Web Server
    </root>
    thats it . then double click on abysws .exe . on hidden icons on desktop yalll be able to see a abyss windows with running 127.0.0.1:9999
    2016-08-03T16:50:26+00:00
    Heres mine:
    2016-08-03T17:03:11+00:00
    right:
    # ::1             localhost
    ( there must be nothing inside this space)
    wrong:
    # ::1             localhost
    127.0.0.1 resources.zune.net.
    i suggest you to use my hosts file (included in rar )
    2016-08-03T17:09:16+00:00
