zune offline firmware update
2016-03-10T06:42:25+00:00
for all you guys that need to restore your zune. ya need to do a 20 gigs partition with win 7 ultimate updated +.net framework all versions installed + zune software 4.8 + firmware update installing msi (x86 or x64)  :
http://fichiers.touslesdrivers.com/30841/Zune-Firmware-x86.msi
http://fichiers.touslesdrivers.com/30842/Zune-Firmware-x64.msi
this will be restoring all zune models ;D
update 04/06/2016 : a little link with allmost all zune hd apps
https://onedrive.live.com/?authkey=%21AN5Z2WThVUIaULs&cid=09C19EF1AFEDDE39&id=9C19EF1AFEDDE39%2144932&parId=9C19EF1AFEDDE39%2144933&action=locate
update 04/09/2016 :
zune software download
https://www.microsoft.com/es-mx/download/details.aspx?id=27163
  1. make a 20 gigs partition on  hdd
  2. .install win 7 ultimate edition
  3. install net framework 3.5.1 + all win 7 updates.
4 . install zune software 4.8 and zune firmware msi- (x86 obviously in 32 bit or -x64 in 64 bit system)
  1. plug the zune to computer. it will be downloading the last version of zune drivers
  2. start zune software and update screen will be displaying in main zune softs screen . thats it.
when you double click zune  firmware-x86 or x64 the msi package install FW .cab files in: C:\ProgramData\Microsoft\Zune\Firmware Updates
and firmware update.xml emulates online mode for restoring ;D
EDIT: FIRMWARE OFFLINE RECOVERY WILL WORK ONLY ON WIN 7.
Windows for home | Other | Apps
    2016-08-02T07:29:54+00:00
    on any windows :
    to put it simple :
    1. install zune software
    2. on control panel enable .net framework 3.5 and 4
    3. open c: drive ... then windows .... next system 32... next drivers ... next etc folder .... look for hosts file... ricght click on hosts file and open with : select notepad ( you can also use text editor but its simple with notepad. now write 127.0.0.1 resources.zune.net. at the files bottom .click on file...save... and close hosts file
    4.  download mega.nz package that i uploaded. unpack and paste in any folder that you want ( some use C:/abyss web server to make it easy as posible)
    5.look for abyss.conf in abyss folder and open with notepad. edit the line "root" for the location of your abyss folder (c:/ abyss for example... again lol)
    6 . double click to execute abyss program
    7 . last step... with abyss running connect zune device and run zune soft... voila ... it will be restoring firmware.
    there are some images in zune firmware restoring package that will help ya. i wrote it as simple as i can describe dude .  edit: 127.0.0.1 resources.zune.net (use spacebar instead of tab. it was a problem that happended to betrayerofhope. hope its clear for ya now ;D . cheers
    2016-08-02T07:30:40+00:00
    Thanks, Francisco... You apparently posted this while I was writing you a new question. I'm trying my best to understand the process, and I really appreciate you being willing to help and being patient with me! : )
    BTW, my name is David.
    2016-08-02T07:34:30+00:00
    nice to meet ya david . i was writing step by step guide ... a "groso modo" ( simple way) cause i dont have a camera :S . BTW... i need a zune hd action jacket but ebay dont have delivery to mexico . how can i get one?
    2016-08-02T08:10:53+00:00
    Hi, Francisco...
    I have to go to sleep soon because I work at 6 a.m., so I will be trying to do this tomorrow after I get off work. I already have the latest version of Zune installed. I have one question on # 2 on your list. I opened my control panel, but I don't know how to enable .net framework 3.5 and 4. I'm in Windows 7. Once I'm in control panel, which tabs do I click to get to where I need to go to enable the .net framework? And are there any special steps once I get there? I think once I know the answer to this, I should be able to get all the way through # 3 on my own!
    Thanks so much and good night,
    David
    2016-08-02T08:21:55+00:00
    I have 3 zunes, 2 30GB and 1 80 GB. (The 80 GB is the one that's bricked.) None of them are HD. I have seen that Craigslist is available in some cities in Mexico, such as Tijuana and Juarez, which are border cities. I don't know where in Mexico you live, but I would try that. I got all 3 of my Zunes and several accessories via Craigslist. They encourage people to buy locally and with cash, so that ripoffs are kept to a minimum! Also, have you tried amazon?
