zune offline firmware update
2016-03-10T06:42:25+00:00
for all you guys that need to restore your zune. ya need to do a 20 gigs partition with win 7 ultimate updated +.net framework all versions installed + zune software 4.8 + firmware update installing msi (x86 or x64)  :
http://fichiers.touslesdrivers.com/30841/Zune-Firmware-x86.msi
http://fichiers.touslesdrivers.com/30842/Zune-Firmware-x64.msi
this will be restoring all zune models ;D
update 04/06/2016 : a little link with allmost all zune hd apps
https://onedrive.live.com/?authkey=%21AN5Z2WThVUIaULs&cid=09C19EF1AFEDDE39&id=9C19EF1AFEDDE39%2144932&parId=9C19EF1AFEDDE39%2144933&action=locate
update 04/09/2016 :
zune software download
https://www.microsoft.com/es-mx/download/details.aspx?id=27163
  1. make a 20 gigs partition on  hdd
  2. .install win 7 ultimate edition
  3. install net framework 3.5.1 + all win 7 updates.
4 . install zune software 4.8 and zune firmware msi- (x86 obviously in 32 bit or -x64 in 64 bit system)
  1. plug the zune to computer. it will be downloading the last version of zune drivers
  2. start zune software and update screen will be displaying in main zune softs screen . thats it.
when you double click zune  firmware-x86 or x64 the msi package install FW .cab files in: C:\ProgramData\Microsoft\Zune\Firmware Updates
and firmware update.xml emulates online mode for restoring ;D
EDIT: FIRMWARE OFFLINE RECOVERY WILL WORK ONLY ON WIN 7.
Windows for home | Other | Apps
  1. Deleted
    2016-03-30T09:44:26+00:00
    Hi!
    Can You give us a step by stepn instruction, specifically interested in how to skip the automatic update method in zune software.
    Or, if you write it done in the past, the link ismore than enough :)
    thanks a lot
    2016-04-01T16:10:24+00:00
    I installed the above, but it doesn't do anything. it keeps checking for the firmware online, failing
  4. Deleted
  5. Deleted
