I don't understand the step install and use it. what is "run abyss server with default connection 80 and ip : 127.0.0.1"??
I use win 10 and I don't want to re-install win 7. how I can fix this issue
for all you guys that need to restore your zune. ya need to do a 20 gigs partition with win 7 ultimate updated +.net framework all versions installed + zune software 4.8 + firmware update installing msi (x86 or x64) :
http://fichiers.touslesdrivers.com/30841/Zune-Firmware-x86.msi
http://fichiers.touslesdrivers.com/30842/Zune-Firmware-x64.msi
this will be restoring all zune models ;D
update 04/06/2016 : a little link with allmost all zune hd apps
update 04/09/2016 :
zune software download
https://www.microsoft.com/es-mx/download/details.aspx?id=27163
4 . install zune software 4.8 and zune firmware msi- (x86 obviously in 32 bit or -x64 in 64 bit system)
when you double click zune firmware-x86 or x64 the msi package install FW .cab files in: C:\ProgramData\Microsoft\Zune\Firmware Updates
and firmware update.xml emulates online mode for restoring ;D
EDIT: FIRMWARE OFFLINE RECOVERY WILL WORK ONLY ON WIN 7.
firmware package and abyss web server (for all win versions ....) in portable mode with instrcutions. EDIT : TESTED IN WIN 7 AND WORKED IN BETA MODE .... IVE ALREADY TESTED IN WINDOWS 10 WITH SAME results . work like a charm
no need to use zune .msi x86 again or needing to install win 7 . just unpack and relocate files to do the thing ;D . thanks to ferrango for contributing to the final version and redizune web page for giving me extra hands ;D (all credit about zune.prod.xml its to them :D)
download this and follow steps. it aint so tough lol:
https://mega.nz/#!FVtWAByS!tdU1n9VOTtjeBTWm0HUHqKJtATaVNLG9plOZDjLO9mw
glad that worked mate. i released abyss dumb proof files . ;D
I tried this, and it worked like a champ, on XP no less.
The process of extracting the firmware files from the msi was a little tricky, because I don't think the command line extractor liked the spaces in my file paths. So, I chose folder names without spaces, and the extract worked.
I used the Abyss Web Server, and had no problem setting it up.
Follow the instructions on the link above, and you'll be reloading your Zune firmware, Microsoft be damned.
Thanks to those who figured this out.
no prob dude. im going to upload hosts file ... firmware package and abyss web server (for all win versions ....) in portable mode with instrcutions. EDIT : TESTED IN WIN 7 AND WORKED IN BETA MODE .... IVE ALREADY TESTED IN WINDOWS 10 WITH SAME results . work like a charm
I picked up a Zune 30 at a garage sale, and am having trouble updating it. I tried the base version of downloading the zune software, and the MSI files, and that didn't work, kept getting error C00D133C, so I tried the method of downloading the Rar file, and the server, and followed all the instructions, and it is getting 1 step further, now it identifies that I don't have the most recent version at least, but then after clicking accept, I am getting the same C00D133C error. I am running Windows 7 Professional Service Pack 1. According to the Abyss server, I am getting an error hit each time I try to update it. Thank you for any assistance you can provide.
Ian
Edit: Never mind, missed the step of moving the CAB files to the HTDOCS folder. This worked. Thank you very much!
