High CPU and memory usage when use Flash Player and images-heavy sites in all browsers or when I download files
2016-05-29T10:02:19+00:00
Hello! From long ago I have issues with high CPU and memory usage when use Flash Player and images-heavy sites or when I download files. The issues happen in Mozilla, Opera, Opera Beta and Chrome. Also when I use fractals rendering software. CPU usage becomes as high that my PC start sounding like a helicopter. Here are some sites I cannot use for that reason (digital design related):
https://www.sumopaint.com/home/#app
http://weavesilk.com/
And this TV site:
http://www.hotstar.com/tv/diya-aur-baati-hum/81/episodes/81/9993
Even if I chose an interactive theme/appearance in Opera Beta (like Star Wars) CPU usage goes wild because Flash Player .
I asked some buddies and they don't have such issues with Sumo and Silk. I checked my anti-vir and it doesn't block anything Adobe or image related. My firewall doesn't block anything too. I posted my question in Adobe Community too (because Flash Player) but still got no reply.
My graphic driver is up to date. Pagefile size is also ok, set min and max to 1.5x of the RAM.
My Hardware and Environment details:
Windows 8.1 (upgraded from Windows 8)
RAM: 4 GB (3.88 Usable)
Intel Celeron CPU G540 2.50 GHz
64-bit OS, x64-based processor
I can't attach my DxDiag.txt file and I'm not sure if it is safe to paste it's content here due to publicly of my post.
2016-06-03T14:39:17+00:00
Thank you for updating on the issue.
Did you try upgrading to Windows 10 after running DISM commands successfully?
You may also create Windows 10 installation media using this link and then try to upgrade to Windows 10.
Refer:
https://www.microsoft.com/en-us/software-download/windows10
I hope this information helps.
Thank you
41 additional answers
    2016-06-03T16:00:36+00:00
    Thank you for the response.
    Yes, you have understood correctly.
    However, Windows 10 upgrade assistant runs and may show a list of programs which may not work with Windows 10 or you may need to reinstall them.
    You may also refer this article:
    http://windows.microsoft.com/en-us/windows-10/upgrade-to-windows-10-faq
    Thank you
    2016-06-03T15:45:29+00:00
    I read carefully everything in the link you sent me and I understood that:
    1. If I click upgrade from the Upgrade Now I'll keep absolutely everything (profile, preferences, programs, files, etc).
    2. If I use Media Creation Tool I can also chose Upgrade from it and will keep absolutely everything too as in #1.
    3. If I use Media Creation Tool, make ISO with it for a clean install and format partition during the clean install I'll lose everything (as I did in my recent Win XP Pro install because I didn't have another choice).
    Did I understand correctly?
    Thank you in advance for having patience with me!! I just have too many programs, too many files, too many customizations in browsers and overall my PC is "my precious" which I adore.;)
    2016-06-03T15:43:44+00:00
    Thank you for your reply.
    Yes, clean installation will remove all files and programs.
    I highly recommend backing up all of your important files and folders onto an external storage device before attempting any type of OS repair, upgrade or clean installation.
    Please keep us posted.
    Thank you
    2016-06-03T15:26:41+00:00
    No, I didn't try to upgrade to Win 10 because I though I need my current Win 8.1 to be up-to-date.
    I'll try to upgrade now but if I don't succeed and make ISO on Flash Drive, that will be a clean new install, won't it? I mean if either upgrade is successful or something goes wrong during the upgrade and it is unsuccessful I'll stay with my current OS and all files and programs kept (I have many Adobe programs which I use often). But if I make clean new install from ISO file, that will remove all my files and programs, won't it?
