Qualcomm Atheros AR3012 Bluetooth not working in Windows 10
2016-07-18T04:46:58+00:00
Qualcomm Athereos AR3012 Bluetooth disabled by Windows 10  need driver or replacement hardware to look for
2020-06-19T20:24:49+00:00
Here is how I made the AR3012 working again on Windows 10 20H1.
  1. remove AR3012 & its drivers completely from 20H1, later let 20H1 detect it as Generic Bluetooth Radio.
  2. download Qualcomm driver v10.0.1.15 from Microsoft Catalog website, install this driver via driver upgrade.
  3. after v10.0.1.15 being installed, you might see additional device named in "Bluetooth LE" as the one in the Kirill's figure.
  4. try to connect any BT device you couldn't connect after upgrading to 20H1, make sure the AR3012 really WORKS.
  5. then download any Qualcomm driver v10.0.3.x (as Kirill mentioned, the newest one is v10.0.3.22, or let Windows Update do it later), upgrade  the driver of AR3012 again with this one.
Notice: NEVER uninstall the v10.0.1.15 while/after upgrading to v10.0.3.x, or the AR3012 will fail again after reboot.
Microsoft Generic Bluetooth Driver -> Qualcomm BT driver v10.0.1.15 -> Qualcomm BT driver v10.0.3.x,
if you did followed the steps, your AR3012 should be working as usual, even after reboot.
Qualcomm Atheros Communications - Bluetooth - 10.0.1.15 (x64)
Qualcomm Atheros Communications - Bluetooth - 10.0.3.22 (x64)
I guess the "Bluetooth LE" is the critical point of this issue.
(I DID hate the crappy W10...... what's M$ doing now? let users recall how windows unstable in 1990s? )
NOTE by MELERIX: by the way, as it is an older driver, it does not support the new Windows 10 shutdown mode called fast startup*, so every time you shut down Windows and then restart it, the device appears with an error, so you have to* disable the fast startup of Windows 10*, in the power options of the control panel.*
206 additional answers
    2020-11-24T01:21:30+00:00
    Downloaded, installed it, restarted, nothing changed. Device is not showing anywhere on the device manager and the computer says that there is no bluetooth on this device, that I should try using an external adapter to add bluetooth capabilities to the computer.
  2. Caio G 11,930 Reputation points Independent Advisor
    2020-11-24T02:17:01+00:00
    What's your laptop model?
    2020-11-24T02:39:27+00:00
    It's a VAIO SVE151J11L.
  4. Caio G 11,930 Reputation points Independent Advisor
    2020-11-24T02:49:42+00:00
    Please click on the following button at Device Manager and check if Windows recognizes your bluetooth card.
