Qualcomm Atheros AR3012 Bluetooth not working in Windows 10
2016-07-18T04:46:58+00:00
Qualcomm Athereos AR3012 Bluetooth disabled by Windows 10  need driver or replacement hardware to look for
2020-06-19T20:24:49+00:00
Here is how I made the AR3012 working again on Windows 10 20H1.
  1. remove AR3012 & its drivers completely from 20H1, later let 20H1 detect it as Generic Bluetooth Radio.
  2. download Qualcomm driver v10.0.1.15 from Microsoft Catalog website, install this driver via driver upgrade.
  3. after v10.0.1.15 being installed, you might see additional device named in "Bluetooth LE" as the one in the Kirill's figure.
  4. try to connect any BT device you couldn't connect after upgrading to 20H1, make sure the AR3012 really WORKS.
  5. then download any Qualcomm driver v10.0.3.x (as Kirill mentioned, the newest one is v10.0.3.22, or let Windows Update do it later), upgrade  the driver of AR3012 again with this one.
Notice: NEVER uninstall the v10.0.1.15 while/after upgrading to v10.0.3.x, or the AR3012 will fail again after reboot.
Microsoft Generic Bluetooth Driver -> Qualcomm BT driver v10.0.1.15 -> Qualcomm BT driver v10.0.3.x,
if you did followed the steps, your AR3012 should be working as usual, even after reboot.
Qualcomm Atheros Communications - Bluetooth - 10.0.1.15 (x64)
Qualcomm Atheros Communications - Bluetooth - 10.0.3.22 (x64)
I guess the "Bluetooth LE" is the critical point of this issue.
(I DID hate the crappy W10...... what's M$ doing now? let users recall how windows unstable in 1990s? )
NOTE by MELERIX: by the way, as it is an older driver, it does not support the new Windows 10 shutdown mode called fast startup*, so every time you shut down Windows and then restart it, the device appears with an error, so you have to* disable the fast startup of Windows 10*, in the power options of the control panel.*
206 additional answers
    2020-09-06T06:51:48+00:00
    With respect to the unknown devices found in the device manager , please download and install the Intel chipset drivers and then restart the PC to verify the Bluetooth issue.
    https://downloadcenter.intel.com/product/1145/I...
    Let me know the status after performing the above.
    Regards
    Shuaib
    Independent Advisor
    2020-09-06T13:45:41+00:00
    Can you provide me the steps to download the bluetooth driver available from Sony for windows 8 in windows 10 ?
    Also, I don't want to break my computer by downloading some unknown intel drivers.
    2020-09-06T16:42:56+00:00
    My issue is that Bluetooth appears in the control panel (as I can seemingly turn it on and off) but Windows simply doesn't recognize Bluetooth devices... I can't pair my phone, Nintendo Joy-Cons, etc
    I had the 10.0.2.11 driver and Windows Update didn't detect a newer driver. Updated to 10.0.3.22 and I experience the same issue :C
    This is how it appears on the Device Manager:
    2020-09-06T18:03:08+00:00
    you need to install 10.0.1.15 to make it work.
