Qualcomm Atheros AR3012 Bluetooth not working in Windows 10
2016-07-18T04:46:58+00:00
Qualcomm Athereos AR3012 Bluetooth disabled by Windows 10  need driver or replacement hardware to look for
2020-06-19T20:24:49+00:00
Here is how I made the AR3012 working again on Windows 10 20H1.
  1. remove AR3012 & its drivers completely from 20H1, later let 20H1 detect it as Generic Bluetooth Radio.
  2. download Qualcomm driver v10.0.1.15 from Microsoft Catalog website, install this driver via driver upgrade.
  3. after v10.0.1.15 being installed, you might see additional device named in "Bluetooth LE" as the one in the Kirill's figure.
  4. try to connect any BT device you couldn't connect after upgrading to 20H1, make sure the AR3012 really WORKS.
  5. then download any Qualcomm driver v10.0.3.x (as Kirill mentioned, the newest one is v10.0.3.22, or let Windows Update do it later), upgrade  the driver of AR3012 again with this one.
Notice: NEVER uninstall the v10.0.1.15 while/after upgrading to v10.0.3.x, or the AR3012 will fail again after reboot.
Microsoft Generic Bluetooth Driver -> Qualcomm BT driver v10.0.1.15 -> Qualcomm BT driver v10.0.3.x,
if you did followed the steps, your AR3012 should be working as usual, even after reboot.
Qualcomm Atheros Communications - Bluetooth - 10.0.1.15 (x64)
Qualcomm Atheros Communications - Bluetooth - 10.0.3.22 (x64)
I guess the "Bluetooth LE" is the critical point of this issue.
(I DID hate the crappy W10...... what's M$ doing now? let users recall how windows unstable in 1990s? )
NOTE by MELERIX: by the way, as it is an older driver, it does not support the new Windows 10 shutdown mode called fast startup*, so every time you shut down Windows and then restart it, the device appears with an error, so you have to* disable the fast startup of Windows 10*, in the power options of the control panel.*
206 additional answers
    2019-10-29T06:06:59+00:00
    Yesterday I moved from Windows 10 1903 to Windows 10 1909 by deleting everything on the hard drive. My Bluetooth headset, which was working properly before the format process, was no longer detected. I tried connecting again after making sure I had installed all the drivers and made all the Windows updates, but the result didn't change.
    I have erased and reinstalled the drivers for my wireless adapter from the device manager maybe 50 times, and finally managed to connect to my headset. After using it for 5-6 hours, I turned off the computer, and when I turned it back on, it didn't detect my headset. In the same way, I erased the driver and reinstalled it repeatedly, but this time it did not work. These are the solutions I've tried:
    1. I ran the "sfc / scannow" command. I did 100% scan and couldn't find anything.
    2. I uninstalled and reinstalled all drivers, including the audio driver.
    3. I updated all drivers with IOBIT Driver Booster.
    4. I installed the drivers that I downloaded from the official site of my computer.
    5. I shut down and restart all of the Bluetooth-related services from the "Services" section of Windows.
    None of the above solve my problem.
    My Bluetooth adapter: Qualcomm Atheros AR3012 Bluetooth 4.0,
    My Bluetooth headset: Xiaomi Airdots Earbuds TWS Bluetooth 5.0 Headset (works on my phone. So there's nothing wrong with the headset)
    I know that Wi-Fi and Bluetooth work on the same adapter. Wi-Fi is working fine. I've been trying to solve this problem for two days. Please help me.
    2019-10-29T06:12:20+00:00
    Hi Batuhan. I'm Greg, an installation specialist, 10 year Windows MVP, and Volunteer Guardian Moderator here to help you.
    How did you obtain media for 1909 which is an Insider build (and therefore as you know not stable)?
    The Qualcomm driver is old and may not be supported for 1909.
    I'll give you everything possible for repairing Bluetooth that works for others. If it fails then because you Clean Installed you may need to reinstall Version 1903 to restore Bluetooth, or you can temporarily replace it with a USB nano BT receiver below. Be sure to also report to Insider forum so they know about this.
    I'll give all possible steps for troubleshooting Bluetooth in order of priority. Many problems right now are being solved by updating to the latest version so if you want to skip to that step see the Repair Install at bottom:
    Try Updating the Bluetooth driver from the PC maker's Support Downloads webpage for your exact model. Install it even if it's the same or newer than the one in Device Manager reached by right clicking the Start button.
    Right click Start button to access Device Manager, locate Bluetooth device (if necessary from View tab Show Hidden Devices), on Driver tab see if Roll Back is available, if not try Update Driver, first automatically, then Browse, then Let Me Pick to try all previously installed Drivers.
    If these fail try to Uninstall the Driver, restart PC to reinstall.
    Make sure you're pairing correctly as shown here: https://support.microsoft.com/en-us/help/15290/...
    See Fixes here which are all working:
    https://support.microsoft.com/en-us/help/14169/...
    https://superuser.com/questions/1017867/make-wi...
    https://answers.microsoft.com/en-us/windows/for...
    Try the Bluetooth troubleshooter at Settings > Update & Security > Troubleshoot.
    Try turning off Fast Startup at Settings > System > Power & Sleep > Additional Power Settings > Choose what Power buttons do > Change settings that are unavailable > uncheck Fast Startup.
    If this is a mic or headset right click Volume icon in System Tray to Open Sound Settings, make sure the correct device is selected for input or output in the dropdown menu.
    Then try pairing again, if necessary run the Bluetooth Troubleshooter again.
    If this was caused by Windows Updates then you can check which were installed at Settings>Update & Security>Windows Update under Installed Updates, then uninstall them from the link there, and hide with the Hide Updates tool downloaded from here: http://download.microsoft.com/download/f/2/2/f2...
    You can also use System Restore to get before the problem began, then check for Updates with the Hide Update tool and hide them: http://home.bt.com/tech-gadgets/computing/how-t...
    If you think the BT adapter has failed, you can replace it easily with a USB nano adapter like this one: https://www.amazon.com/ZEXMTE-Bluetooth-Receive...
    Go over this checklist to make sure the install is set up correctly, optimized for best performance, and any needed repairs get done: http://answers.microsoft.com/en-us/windows/wiki...
    Start with Step 4 to turn off Startup freeloaders which can conflict and cause issues, then Step 7 to check for infection the most thorough way, then step 10 to check for damaged System Files. Then continue with the other steps to go over your install most thoroughly.
    If nothing else helps you can run a Repair Install by installing the Media Creation Tool and choosing from it to Upgrade Now. This reinstalls Windows in about an hour while saving your files, apps and most settings, solves many problems while also bringing it up to the latest version 1903 which you need anyway and by the most stable method. http://windows.microsoft.com/en-us/windows-10/m....
    I hope this helps. Feel free to ask back any questions and let us know how it goes. I will keep working with you until it's resolved.
    ________________________________________________________
    2019-10-29T06:32:08+00:00
    None of your solutions worked for me and I don't want to re-install Windows 10 1903. Because I've installed a lot of programs and don't want to lose all of them for stupid bluetooth issue. Anyways, thanks for your answer.
    2019-10-29T06:35:33+00:00
    I'm glad to help. If it was me and I didn't want to reinstall or wait for stable Version 1909 coming soon, I would buy a $10 bluetooth USB nano adapter like the one in the steps I gave you to use as a backup. Unless your BT adapter died, it should be reparable or start working once you get to a stable version. I gave you everything possible to repair, collected over ten years daily in forums and thousands of cases.
