El Capitan and Microsoft Mouse (IntelliPoint) Not Working
2015-09-11T14:32:37+00:00
After installing the El Capitan GM, the forward/back buttons (side buttons, 4 & 5) on my Microsoft Wireless Mouse 5000 are only registering as left mouse buttons. The most recent driver, Microsoft Mouse 8.2 is installed and shows up in the System Preferences, but appears to not be functioning. MicrosoftMouseHelper is in the login items. Suggestions?
[Moved from Community Participation Center]
There is not an appropriate category to post this question to!
    2015-10-08T21:19:56+00:00
    I'm so grateful I found this post and thread -- in my case, because with El Capitan my Intellitype Keyboard 4000 has also lost all its HotKeys...now I understand why, because I assume it's the same driver issue for the keyboard:
    "Intellitype software doesn't work on El Capitan because of the System Integration Protection feature.
    I disabled rootless through the recovery partition using the csrutil command in the Terminal window. Only then I was able to run Intellitype and Intellimouse apps.
    Apple strongly recommends to leave rootless enabled."
    I'm not going to disable SIP to get those hotkeys back, and I'll keep using my Intellitype because it's the most comfortable, ergonomic keyboard I've ever used, but I sure hope that MS does a quick fix on this.  I miss how fast I could do things with the press of a key with those Hotkeys!
    2015-10-09T12:53:32+00:00
    I just entered keyboard preferences > modifiers keys and changed the behavior of Option and command keys.
    This resolved to use Alt key as Command key.
    2015-10-09T12:56:30+00:00
    I did try this as well and the driver just wasn't the same as the one from Microsoft.  My mouse is difficult to steer and control.  Guess I'll have to wait until Microsoft comes up with their own driver unfortunately.
    2015-10-09T12:59:06+00:00
    I've got the exact same mouse and it the solution did not work for me either.  Also tried USB overdrive but it doesn't quite match what microsoft has.  It just doesn't feel right.  I can't get the acceleration to match the speed so I can't control the cursor as I've been accustomed to over the years.
    2015-10-09T21:32:46+00:00
    Yes!  Thanks!  Isn't it great one can at least do that...and the mute, volume, and play/stop button still work...I guess that's standard...my temporary solution is to use Keyboard Maestro to program the F1-F13 keys to the Hotkeys I used to use...but, I hope that MS eventually updates the mouse *and* keyboard driver for El Capitan!
