....., there is one thing you can check...it has a built-in battery monitor, if you go to settings -> system -> battery saver -> battery use it shows whats eating up your battery...that should help you narrow things down.
Although I thought that this would have been helpful it changes every time you look at, first time its the settings, next time you look at it its the lock screen. Very inconsistent.
