Very good one, LOL, "W10 work-in-progress..."
MS should use it as a logo.
The post is still valid even today as of 10th of February
My Lumia 950 was at 95% battery today. I had it in my pocket for 2 hours and didn't take it out once or use it in any ways. After 2 hours I pulled my phone out and it was at 72% and it felt very hot. Is this the experience others are having with their Lumia 950 or does this sound like I may have a defective phone and/or battery?
Here we are, and another month has passed without noticeable improvements to what I strongly believe is a software problem. Typically, my 950 Dual SIM draws 7%/hour when in standby, which is waaaay too much. Sometimes, closing all apps will pull the power drain down to 1-2%/hour, which is what you should expect from a new-ish phone. But I shouldn't have to close apps to save my battery! We stopped doing that years ago, and power management was never an issue on WP7-8. What has happened to quality control back at Redmond lately?
I shouldn't have to do this, but I have enabled developer mode on my phone to get the web based "task manager", in hopes that it would pinpoint what causes all the power drain. Edge is still a likely culprit, but also some anonymous svchost process that does dog knows what. There is clearly something wrong with Edge, that typically pegs the CPU on any non-trivial web page it renders, even if the display is completely static, but then we're talking 20-30%/hour and the phone getting almost too hot to touch.
So, is anybody at Microsoft interested in taking time off their iPhone/Android development to have a look at what keeps draining the battery when the phone is in standby? I hear there are heaps of telemetry in Windows 10, so the answer is probably there in all the data that you've collected from (slightly deranged) people like me actually trying to use Windows phones daily.
This phone is ridiculous. I can charge it all night and the battery dies mid-day without me even using it. It gets very hot also. I think Microsoft should refund everybody their money because they didn't deliver what they promised.
- Battery sucks.
- Apps that were promised don't exist
- Future of eco system not promising
- Facial recognition a gimmick, I can unlock the phone 3 times with password by the time it recognizes my face.
There are a ton of suggestions on this thread for preserving battery life. Android phones suffer the same issue. So many features all vying for processor time means low battery life. The biggest problems I had initially with the battery life was the constant WiFi searching when driving around and my music library trying to download to my new device. Disable the auto-connect wifi feature and make sure nothing is downloading in the background. There are also some pretty resource intensive apps that like to run in the background. See what's running and disable them.
To figure out if maybe cellular data or wifi are causing the drain, throw your phone into airplane mode for a little bit. See how that affects the battery life. Sometimes crappy wifi connections are the culprit.
I don't know how long you've had your phone, but I've had mine since the release last year, and my battery life is pretty stellar. Maybe these batteries need to burn in a little bit?
