Battery drain while in sleep mode (Windows 10)
2016-01-19T04:18:18+00:00
Hello
I have an Asus GL551. It original had Windows 8.1 on it but I upgraded to Windows 10 a few months ago. Ever since it has been running Windows 10 the battery will drain completely within 10-12 hours while in sleep mode. When it had Windows 8.1 this was not an issue. There would still be plenty of battery power even after a few days of not being used and in sleep mode.
I suspect that is is coming out of sleep mode periodically and draining the battery. Just the other day I had been watching a YouTube video. When It finished I closed the lid of the laptop putting it to sleep. About two hours later, with the lid closed the laptop started playing the Youtube video all by itself. I had not touched the computer and the lid was still closed.
Any ideas?
Kevin
Windows for home | Windows 10 | Sleep and Power on, off
    2015-10-12T01:16:20+00:00
    Thank you for posting on Microsoft Community.
    This issue can be caused due to power settings.
    I would suggest you to provide us some information to help you better.
    1. Did you make any changes on to your computer prior to this issue?
    2. What is the make and model of your computer?
    I would suggest you to follow the methods given below and check.
    Method 1: I would suggest you to run the Power troubleshooterand check if it helps.
    a)    Press the ‘Windows + X’ key on the keyboard and select Control Panel.
    b)    Type troubleshooter in the search box and then press enter.
    c)    Select Troubleshooting. Click on view all and select Power.
    d)   Click next and follow the on-screen instructions.
    If issue didn’t get resolve try method 2.
    Method 2: I would suggest you to restore default settings of power plan and check if it helps.
    5. Press Windows + X, and select the option Control Panel (Classic View).
    6. Click on the Power Options icon.
    7. Click on Change plan settings.
    8. Select the option “Restore default settings for this plan”.
    If issue still persists try method 3.
    Method 3: Create a power plan
    6. Type Power in search box
    7. Select "Choose a Power Plan"
    8. Click where it says "Create a power plan" in the area on the left side of the Power options window.
    9. Select a power plan to start with such as "Balanced" or "High performance" and then click "Next."
    10. Select a number of minutes you want both the display and the computer sleep mode, and then click "Create."
    You can refer to the article given below.
    Power plans: frequently asked questions. Refer to the section “Can I create a power plan?
    http://windows.microsoft.com/en-IN/windows-8/power-plans-faq
    (Applies to Windows 10)
    Keep us informed if the issue is resolved. We are glad to help you further.
    2015-10-19T23:18:02+00:00
    Thank you for your reply. I have tried the suggested troubleshooting method and tested the device usage for a few days, but the device still has high CPU utilization and it also NEVER, EVER....EVER enters into (DRIPS) Deep sleep.
    The device is a low powered one with the Intel Atom Chipset, 1GB RAM and 16GB Storage, with a 15,751 mWh battery. It is the iView Suprapad i800QW.
    If the issue can be helped that would be much appreciated.
    2015-10-24T19:03:01+00:00
    I poked around online to try and see what solutions are out there.  I was able to run the powercfg/energy report in cmd prompt and got the report below.  The problem is that I am not technical enough to know how to resolve the errors found.   Does anyone know if there is step-by-step documentation out there to walk a relative lay person through these issues?
    Analysis Results Errors
    System Availability Requests:System Required Request
    The device or driver has made a request to prevent the system from automatically entering sleep.
    Driver Name \FileSystem\srvnet
    USB Suspend:USB Device not Entering Selective Suspend
    This device did not enter the USB Selective Suspend state. Processor power management may be prevented when this USB device is not in the Selective Suspend state. Note that this issue will not prevent the system from sleeping.
    Device Name USB Composite Device
    Host Controller ID PCI\VEN_8086&DEV_9CB1
    Host Controller Location PCI bus 0, device 20, function 0
    Device ID USB\VID_1058&PID_1102
    Port Path 1,4,3
    Device Name Generic USB Hub
    Device ID USB\VID_1A40&PID_0101
    Port Path 1,4
    Device ID USB\VID_046D&PID_C52B
    Port Path 1,2
    Device ID USB\VID_17E9&PID_4307
    Port Path 12,1
    Device ID USB\VID_2109&PID_2811
    Port Path 1
    Device Name Generic SuperSpeed USB Hub
    Device ID USB\VID_2109&PID_8110
    Port Path 12
    CPU Utilization:Processor utilization is high
    The average processor utilization during the trace was high. The system will consume less power when the average processor utilization is very low. Review processor utilization for individual processes to determine which applications and services contribute the most to total processor utilization.
    Average Utilization (%) 11.20
    Platform Power Management Capabilities:PCI Express Active-State Power Management (ASPM) Disabled
    PCI Express Active-State Power Management (ASPM) has been disabled due to a known incompatibility with the hardware in this computer.
    Warnings
    Platform Timer Resolution:Platform Timer Resolution
    The default platform timer resolution is 15.6ms (15625000ns) and should be used whenever the system is idle. If the timer resolution is increased, processor power management technologies may not be effective. The timer resolution may be increased due to multimedia playback or graphical animations.
    Current Timer Resolution (100ns units) 10007
    Maximum Timer Period (100ns units) 156250
    Platform Timer Resolution:Outstanding Timer Request
    A program or service has requested a timer resolution smaller than the platform maximum timer resolution.
    Requested Period 10000
    Requesting Process ID 8468
    Requesting Process Path \Device\HarddiskVolume3\Program Files (x86)\Google\Chrome\Application\chrome.exe
    Power Policy:Display timeout is long (On Battery)
    The display is configured to turn off after longer than 5 minutes.
    Timeout (seconds) 600
    USB Suspend:USB Device Rarely Entering Selective Suspend
    This device intermittently entered the USB Selective Suspend state during the trace. Processor power management may be prevented when this USB device is not in the Selective Suspend state. Note that this issue will not prevent the system from sleeping.
    Device Name USB Input Device
    Device ID USB\VID_048D&PID_8386
    Port Path 8
    Time Suspended (%) 9
    CPU Utilization:Individual process with significant processor utilization.
    This process is responsible for a significant portion of the total processor utilization recorded during the trace.
    Process Name chrome.exe
    PID 8468
    Average Utilization (%) 1.85
    Module Average Module Utilization (%)
    \Device\HarddiskVolume3\Program Files (x86)\Google\Chrome\Application\46.0.2490.71\chrome_child.dll 1.01
    \Device\HarddiskVolume3\Windows\SysWOW64\ntdll.dll 0.32
    \SystemRoot\system32\ntoskrnl.exe 0.31
    PID 10848
    Average Utilization (%) 1.66
    \Device\HarddiskVolume3\Program Files (x86)\Google\Chrome\Application\46.0.2490.71\chrome.dll 0.96
    \SystemRoot\system32\ntoskrnl.exe 0.25
    \Device\HarddiskVolume3\Windows\SysWOW64\ntdll.dll 0.18
    PID 7516
    Average Utilization (%) 1.55
    \Device\HarddiskVolume3\Program Files (x86)\Google\Chrome\Application\46.0.2490.71\chrome_child.dll 0.56
    PID 996
    Average Utilization (%) 0.80
    \Device\HarddiskVolume3\Program Files (x86)\Google\Chrome\Application\46.0.2490.71\chrome_child.dll 0.44
    \SystemRoot\system32\ntoskrnl.exe 0.14
    \Device\HarddiskVolume3\Windows\SysWOW64\ntdll.dll 0.12
    Process Name System
    PID 4
    Average Utilization (%) 0.65
    \SystemRoot\system32\ntoskrnl.exe 0.29
    \SystemRoot\system32\DRIVERS\bcmwl63a.sys 0.13
    \SystemRoot\system32\hal.dll 0.07
    PID 3820
    Average Utilization (%) 0.39
    \SystemRoot\system32\ntoskrnl.exe 0.08
    \Device\HarddiskVolume3\Program Files (x86)\Google\Chrome\Application\46.0.2490.71\libglesv2.dll 0.06
    \Device\HarddiskVolume3\Program Files (x86)\Google\Chrome\Application\46.0.2490.71\chrome_child.dll 0.05
    PID 10752
    Average Utilization (%) 0.37
    \Device\HarddiskVolume3\Program Files (x86)\Google\Chrome\Application\46.0.2490.71\chrome_child.dll 0.25
    \SystemRoot\system32\ntoskrnl.exe 0.04
    \Device\HarddiskVolume3\Windows\SysWOW64\ntdll.dll 0.03
    Information
    Platform Timer Resolution:Timer Request Stack
    The stack of modules responsible for the lowest platform timer setting in this process.
    Power Policy:Active Power Plan
    The current power plan in use
    Plan Name OEM Balanced
    Plan GUID {381b4222-f694-41f0-9685-ff5bb260df2e}
    Power Policy:Power Plan Personality (On Battery)
    The personality of the current power plan when the system is on battery power.
    Personality Balanced
    Power Policy:Video Quality (On Battery)
    Enables Windows Media Player to optimize for quality or power savings when playing video.
    Quality Mode Balance Video Quality and Power Savings
    Power Policy:Power Plan Personality (Plugged In)
    The personality of the current power plan when the system is plugged in.
    Power Policy:802.11 Radio Power Policy is Maximum Performance (Plugged In)
    The current power policy for 802.11-compatible wireless network adapters is not configured to use low-power modes.
    Power Policy:Video quality (Plugged In)
    Quality Mode Optimize for Video Quality
    Battery:Battery Information
    Battery ID 123456789GetacSDS-BAT
    Manufacturer Getac
    Serial Number 123456789
    Chemistry LiP
    Long Term 1
    Sealed 0
    Design Capacity 44000
    Last Full Charge 43260
    Platform Power Management Capabilities:Supported Sleep States
    Sleep states allow the computer to enter low-power modes after a period of inactivity. The S3 sleep state is the default sleep state for Windows platforms. The S3 sleep state consumes only enough power to preserve memory contents and allow the computer to resume working quickly. Very few platforms support the S1 or S2 Sleep states.
    S1 Sleep Supported false
    S2 Sleep Supported false
    S3 Sleep Supported true
    S4 Sleep Supported true
    Platform Power Management Capabilities:Connected Standby Support
    Connected standby allows the computer to enter a low-power mode in which it is always on and connected. If supported, connected standby is used instead of system sleep states.
    Connected Standby Supported false
    Platform Power Management Capabilities:Adaptive Display Brightness is supported.
    This computer enables Windows to automatically control the brightness of the integrated display.
    Platform Power Management Capabilities:Processor Power Management Capabilities
    Effective processor power management enables the computer to automatically balance performance and energy consumption.
    Group 0
    Index 0
    Idle State Count 3
    Idle State Type ACPI Idle (C) States
    Nominal Frequency (MHz) 1401
    Maximum Performance Percentage 100
    Lowest Performance Percentage 35
    Lowest Throttle Percentage 4
    Performance Controls Type ACPI Performance (P) / Throttle (T) States
    Group 0
    Index 1
    Idle State Count 3
    Group 0
    Index 2
    Idle State Count 3
    Group 0
    Index 3
    Idle State Count 3
    Device Drivers:Analysis Success
    Analysis was successful. No energy efficiency problems were found. No information was returned.
    2015-10-24T23:53:37+00:00
    Hi Lori,
    Thanks for posting your query on Microsoft Community.
    This may be arise if you did not configured the power settings properly.
    I suggest you to run the Power troubleshooter and check if it resolves the issue.
    1) Press Windows + X keys on the keyboard and select Control Panel.
    2) Type Troubleshooting in the search bar on the Control Panel.
    3) Click on View allon the left navigation pane. Click on Power.
    4) Click on Advanced on the power troubleshooter dialog box and click on Run as administrator (Enter the credentials if required).
    5) Click on Next and follow onscreen instruction complete the Power troubleshooter.
    Hope it helps, reply to us with the status of your issue. We will be happy to assist you.
    2015-11-12T01:22:36+00:00
    I looked at your ad about your battery diying on windows 10.   cause  I am having the same problem.  never done this before until windows 10.  and things freezing up on it.    I don't think windows is good as they say.  started out good.
