Battery drain while in sleep mode (Windows 10)
2016-01-19T04:18:18+00:00
Hello
I have an Asus GL551. It original had Windows 8.1 on it but I upgraded to Windows 10 a few months ago. Ever since it has been running Windows 10 the battery will drain completely within 10-12 hours while in sleep mode. When it had Windows 8.1 this was not an issue. There would still be plenty of battery power even after a few days of not being used and in sleep mode.
I suspect that is is coming out of sleep mode periodically and draining the battery. Just the other day I had been watching a YouTube video. When It finished I closed the lid of the laptop putting it to sleep. About two hours later, with the lid closed the laptop started playing the Youtube video all by itself. I had not touched the computer and the lid was still closed.
Any ideas?
Kevin
Windows for home | Windows 10 | Sleep and Power on, off
    2022-06-04T16:29:07+00:00
    Okay, thank you very much for the clarification. Another procedure you can also try is doing a BIOS update on your laptop. What brand and model is it?
    2022-12-09T20:20:39+00:00
    2022-12-30T17:39:54+00:00
    I think A.User is a bot.....always same cut and paste answer even after SEVERAL users said it was NO HELP.
    2022-12-30T17:43:33+00:00
    CHANGE YOUR USER NAME TO A. BOT!
