Then we continue with steps which will lead to resolution, just as we do for thousands of others who
always reach a solution if patient and cooperative.
The Generic Pro key is only used to change the version to Pro. Is it still at Pro? Then it worked.
Now as to reinstating Digital Entitlement so it remains and is stable:
Right click Start button to open Admin Command Prompt
Type slui 4, press Enter.
Follow prompts to refresh your activation ID in MS Servers.
If it fails stay on the line for an agent, explain the situation.
If they are not as helpful as they should be, then depending upon where you go the original Pro Upgrade you may need to reactivate. If Store, sign in there to reapply your Pro Upgrade. If
using a Product Key, after confirming Version 1511 at Settings>System>About, insert the key at the link there.
