Lumia 950XL 5ghz Wifi issue
2016-01-13T02:33:23+00:00
So I have found when using my 5Ghz N network the phone will lose all WiFi networking.   On first use, it will connect up OK.  But let it sit and come back to it, it will have lost the WiFi network and the ability to see any other WiFi network with "no networks found".  Only a phone reboot will fix it until it happens again.
So far I've experienced it on my Linksys E8350 (supposed AC2400 and MIMO which the 950XL claims to support).  My Wifi router is set for Wireless A or N on 5Ghz, while it can do N, B, or G on 2.4
My workaround is to  only connect to the 2.4Ghz WiFi at this point.
Anyone else experiencing complete WiFi radio failure like this?
    2016-01-16T23:00:40+00:00
    Having a similar issue with my 950XL (using the latest firmware and W10 build 10586.29). When I connect to the 5 Ghz band on my Xfinity modem/router, the signal will be fine for a short while but quickly begins to slow down. Eventually my phone loses the connection, and the 5 Ghz band disappears from the list of available networks. Rebooting the phone causes the 5 Ghz band to reappear, but connecting to it again has the same results.
    Do not have any of these problems using the 2.4 Ghz network.
    I suspect this is indicative of a firmware or driver problem because I do not have the same issues when connecting to the 5 Ghz network with my old Lumia 920 which is running the latest Windows 10 Insider build.
  2. Deleted
    2016-01-18T14:19:59+00:00
    Router: Netgear Nighthawk R7000
    Firmware: 1.0.4.30_1.1.67
    I didn't have this problem with 1520 on Insiders build before switching to 950 XL.
    2016-01-18T14:25:21+00:00
    Please, continue and select ‘Me Too’ in that thread…
    Then you are subscribed to updates automatically. When anything changes, you get notified by E-mail. Furthermore, only one thread must be updated. Although this happens for many users, please, post the brand/model (and if possible the firmware version) of your Wi-Fi access point there again. That helps, to speed-up reproducing this issue – because I am not able to reproduce it, yet.
    2016-01-18T16:24:02+00:00
    I've had this same problem with my 950XL (hardware rev 4.0.3.1) since day one. I have seen it on build .0, .29 and with original firmware and updated firmware 01078.00027.15506.02005).
    I own two routers, a Netgear R6300 (firmware V1.0.2.78_1.0.58 ), and a Netgear WNDR3700 (firmware v1.0.7.98NA). Both routers have 2.4ghz and 5ghz networks. When the problem happens to my 950XL both 5ghz networks (from both routers) drop. If I take my phone to other locations I can't see any 5ghz networks there either, until I reboot the phone. Even if I do not connect to a 5ghz band, Wifi will stop being able to see 5ghz networks. Strangely, sometimes if I wait a few days without rebooting I see the 5ghz bands again.
    As to clicking the "me too" link, There are several threads floating around.
    This one has 9 "me toos":
    These threads on Windows Central have many posts:
    People seem to be having trouble with AC capable routers, and some have had luck disabling AC compatibility. My routers don't seem to have that option - all I can do is drop the max connection speed from 1300 to 600 or 300. I've tried that but still lose my 5ghz bands on my XL. For now I'm just using 2.4ghz connections.
