Lumia 950 won't turn on
2016-01-06T11:59:15+00:00
After nearly two weeks my phone turned off with roughly 30% battery and it doesn't turn back on,recovery tool doesn't recognize it and when i plug it in to my pc or when i plug the charger nothing happens but it vibrates shortly every minute or so the whole time it's plugged in,is there any way i can get it back to life ? Thanks.
    2016-01-06T14:58:37+00:00
    Still doesn't work,it vibrates when i press power and volume down and i release it after it vibrates the second time but still nothing happens.Also i haven't done any changes recently,only after i got it i did an update wich was about two weeks ago,when this happend i did nothing ''special''to the phone,just everyday use.
    2016-01-06T14:38:05+00:00
    Hi Augustin,
    Thank you for posting on Microsoft Communities.
    I will be glad to help you with the issue you have with the phone. I understand the frustration when things don't work the way it should.
    Please answer the following for us to assist you better:
    1. Did you make any changes to the phone prior to the issue?
    2. Which was the latest built installed on the phone?
    I suggest you to follow the below link and check if it works.
    http://windows.microsoft.com/en-us/windows-10/restart-my-phone
    Please reply with the results, we will be glad to help you further.
    Thank you.
