Side by side configuration is incorrect
2015-08-06T16:50:47+00:00
WINDOWS 10 Pro error The application has failed to start because the side by side configuration is incorrect please see the application event log or use the command line sxstrace.exe tool for more detail.
I am getting the error "
"WINDOWS 10 error The application has failed to start because the side by side configuration is incorrect please see the application event log or use the command line sxstrace.exe tool for more detail." for every application that i try to launch.
I can't Install Quick Time App
Please help
*Modified title for accuracy*
*Original title: "WINDOWS 10 error The application has failed to start because the side by side configuration is incorrect.*
2015-08-09T20:24:51+00:00
Thank you for posting on Microsoft Community. I understand the inconvenience you are facing. I apologies for the delay in reply. I will certainly help you with this.
This error may happen due to system file corruption or Visual C++ redistributable package corruption. I suggest you to follow the below given methods:
Method 1:
Kindly download and install Microsoft Visual C++ 2013 Redistributable Packagefrom below given link and check if it helps:
Visual C++ Redistributable Packages for Visual Studio 2013
http://www.microsoft.com/en-in/download/details.aspx?id=40784
Method 2:
I suggest you to run System file checker. System File checker (SFC) scan is done to check if there are any corrupted system files that could be causing this issue. Kindly follow the below given steps:
  • Press Windows key + X, select Command prompt (Admin) to bring up elevated Command prompt.
  • In Command prompt type sfc/scannow and press enter.
  • Restart the computer.
If no corrupted system files were found in the previous state, then I suggest you to try the following steps:
  • Open command prompt by pressing Windows key + X and selecting “Command prompt admin”.
  • In command prompt, type the following commands and press Enter after each command:
                DISM.exe /Online /Cleanup-image /Scanhealth
DISM.exe /Online /Cleanup-image /Restorehealth
  • Close the command prompt and restart the PC and check if it works.
Hope this information helps. Please post back with the results, we will be glad to assist you further.
Thank you.
2016-08-25T01:24:13+00:00
The problem was corrupted Google Chrome, my default browser.  I deleted the program and installed a new one.  It works now.
600+ people found this answer helpful.
196 additional answers
    2020-03-19T09:56:11+00:00
    Method 1:
    Method 2:
    Thank you.
    Hi , I have the problem " side-by-side configuration is incorrect " from long time ago . it appears with most of the applications I try to open , like ( Microsoft office , mozilla Firefox , IDM , …) and I can't install and run any new application .
    I tried everything to solve that , even the method of
    it didn't solve my problem . showing that a file was corrupted and system couldn't solve it . for online repair see the log...… , and for offline repair see the log...…. .
    please help me . I am disappointed ..
