Problem with Windows 10 & Minesweeper Adventure
2015-08-18T10:49:10+00:00
I've recently upgraded to Windows 10 from Windows 8.1.  I've played Minesweeper Adventure & Treasure Hunt numerous times when I had Windows 8.1 with no difficulty.  Now that I've upgraded to Windows 10, the screen is blacked off to the right.  The game board that is covered up by the black screen will move to a point and then stop.  Arrow buttons will not move the screen like they did in Windows 8.1.  At no point is the entire level of the game able to be seen like it was seen in Windows 8.1.
I haven't checked to see if it happens in other games.
Does anyone know what might be wrong or how to fix it?
    2016-05-03T15:22:21+00:00
    I had the same problem. I uninstalled microsoft security update kb3147458 for the fix. Of course it reinstalls in a week or so and again screws up the game, so again I uninstall the update for the fix. Again, the game runs right. Have done this for the last six weeks. Keep hoping microsoft will realize that something in that update is causing the problem. Hope this helps.
    2016-05-14T08:26:45+00:00
    I HAVE THE SAME PROBLEM EVERY TIME WINDOWS DOES AN UPGRADE. HOW DOES ONE FIX THIS ?????
    2016-05-14T08:33:50+00:00
    Bit long winded but have found that can still play the game by getting close to the hidden portion on the right hand side, stop, zoom in, use the right arrow to move cursor over to the hidden portion of the board which will be visible when zoomed in and then finish off clearing the last two rows and exit.  Hopefully Microsoft will solve the problem with an update but at least can finish each level.  Bit addictive this game :)
    NOT HELPFUL....THEY SHOULD FIX THE PROBLEM.....HAS GONE ON FOR WELL OVER A YEAR NOW EACH TIME THEY UPDATE WINDOW SYSTEM THEY MESS UP THE RIGHT HAND SIDE OF THE MINESWEEP GAME !!!!
    2016-05-14T08:37:04+00:00
    OVER A YEAR AND STILL THEY MESS UP THE RIGHT SIDE OF THE MINESWEEP GAME EVERY TIME MICROSOFT "UPGRADES" THEIR SYSTEM.
    2016-05-14T08:42:20+00:00
    WINDOWS JUST UP DATED THEIR SYSTEM AND AGAIN A YEAR LATER THEY WIPED OUT THE RIGHT HAND SIDE OF THE MINESWEEP GAME. WHY DO THEY KEEP MESSING UP THE MINESWEEP  GAME WHEN THEY UPDATE....THEY HAVE HAD OVER A YEAR TO FIX THIS PROBLEM. GIVE ME AN ANSWER PLEASE.
