Network Problem in Signing in Nokia Account
2014-10-08T08:30:41+00:00
Hi Team,
In the past few days I am having a problem in loggin in the Nokia Account of my Lumia 630,It shows connecting ->gathering your Options --> then shows Network Problem Try again Later.However all of the internet related Applications are working fine .Have tried resetting .Didn't worked.My apps are all upto date.Can anyone please suggest me .I am not able to use the MIX Radio due to This
Thanks iN Advance
    2014-11-14T18:05:36+00:00
    hi
    im facing the same network issue
    my IP is 23.52.71.237
    kindly resolve my problem
    2014-11-21T16:17:59+00:00
    Am also facing same issue
    Ip is 23.35.13.204 plz help am from India
    2014-11-25T10:55:09+00:00
    Hi
    DNSLookup for account.nokia.com - 23.35.13.204
    Kindly resolve the issue.
    Regards,
    Nandan
  4. Deleted
    2014-11-29T14:18:42+00:00
    Even I am using same Airtel sim. Is this a issue with network?
