Network Problem in Signing in Nokia Account
2014-10-08T08:30:41+00:00
Hi Team,
In the past few days I am having a problem in loggin in the Nokia Account of my Lumia 630,It shows connecting ->gathering your Options --> then shows Network Problem Try again Later.However all of the internet related Applications are working fine .Have tried resetting .Didn't worked.My apps are all upto date.Can anyone please suggest me .I am not able to use the MIX Radio due to This
Thanks iN Advance
    2014-10-28T10:54:47+00:00
    thank you for sharing your results. Which network operator do you use, in which country?
    2014-10-29T16:52:10+00:00
    I am from India.
    At home my network is Airtel broadband, account.nokia.com connecting to 23.207.134.242
    At office i don't know about service provider,  account.nokia.com connecting to 23.57.199.249
    2014-10-29T20:49:46+00:00
    Hey,i'm using lumia 530 and i'm unable to login to my nokia account...please help my ip adress is 23.211.147.120
    2014-10-29T21:06:11+00:00
    Hey,i too face the same problem in my lumia 530,i'm from india and i use airtel 2g mobile network....my i.p adress is 23.211.147.120
  5. Deleted
