Network Problem in Signing in Nokia Account
2014-10-08T08:30:41+00:00
Hi Team,
In the past few days I am having a problem in loggin in the Nokia Account of my Lumia 630,It shows connecting ->gathering your Options --> then shows Network Problem Try again Later.However all of the internet related Applications are working fine .Have tried resetting .Didn't worked.My apps are all upto date.Can anyone please suggest me .I am not able to use the MIX Radio due to This
Thanks iN Advance
    2016-02-14T13:28:58+00:00
    Which service (Maps, Sync, Music, …) do you want to use exactly? Then, I might be able to name a workaround.
    2016-08-14T18:00:31+00:00
    Hi Team,
    Thanks iN Advance
    have problems for signing in my phone Nokia Lumia 630
    2016-08-14T19:48:52+00:00
    Read the thread before posting the same question over and over. this has been answered a long time ago.
    2016-10-25T10:38:36+00:00
    Hello
     I cannot agree with you. My Nokia account or something related with it worked fine but few days ago I had lost it with all data related with it (sms, contacts, etc.) I spoke with MS support and they told me that Nokia account will be available for Nokia devices only. My error is the same "Network Problem". Support told me to make a hard reset and try to connect this account again. I’m not sure if this is good idea, I would rather fix current situation. Can you tell me why I got "Network Problem" error also when I try to switch on MS account? You know, there is an option “Use different Nokia account” or I’m usually logging with …” sorry if there will be some differences - translating form Polish.
    Marcin
    2016-10-25T11:27:17+00:00
    Hello
    Marcin
    That is just a miscommunication. Nokia accounts  - actual "Nokia accounts", not "Microsoft accounts that you use on the nokia phone" haven't existed in years. You can't use something that doesn't exist.
    Also, nokia accounts have nothing to do with SMS and contact backups. NOTHING AT ALL. that is what the Microsoft account is there for in the phone.
