Network Problem in Signing in Nokia Account
2014-10-08T08:30:41+00:00
Hi Team,
In the past few days I am having a problem in loggin in the Nokia Account of my Lumia 630,It shows connecting ->gathering your Options --> then shows Network Problem Try again Later.However all of the internet related Applications are working fine .Have tried resetting .Didn't worked.My apps are all upto date.Can anyone please suggest me .I am not able to use the MIX Radio due to This
Thanks iN Advance
    2014-10-08T14:54:16+00:00
    that is interesting information especially because it works here in Germany. Which network did you try first (Wi-Fi and/or GSM): Which Internet Service Provider (ISP) do you use with that, in which country?
    2014-10-08T14:26:28+00:00
    Hello Subhodeep47
    I Have the same issue with Lumia 925, i have tried to reset many times but same issue.
    Surprisingly when i connected to Wifi in My office, nokia account works and after that it continues to work every where else. Hope this helps.
    Pavan
  3. Deleted
    2014-10-08T12:15:08+00:00
    I am able to login via PC.Its purely a software issue.Is there any fix for this.Googling reports lot of users having same problem.
    2014-10-08T09:00:14+00:00
    hi mate, have u tried contacting your local Nokia Care point or emailing Nokia for support for your account? also check that you can login via PC
