I have the same problem with video controls. Though today I installed Adobe. The menus in PS and Illustrator are very small! And more weird than this is that Indesign is normal. I am really very annoyd from this issue. Can't we do anything about it? :S
Video controls are small - How to resize?
I just got a new computer and every video I've watched the video controls (play button, video timeline, expand, etc) are all very small, on every website and on different video players. The video player size is fine, just not the controls. I've tried changing the resolution, it just changes the screen size, doesn't work. IE video controls seem to ok, but Firefox is where the issue is.
Laptop is a HP Envy 14 sleekbook.
2016-01-08T18:42:14+00:00 -
2016-01-08T19:11:30+00:00 Hey brother Ahmad.. Adobe has taken the matter into their hands and at least taken care of the issue from their end. The new versions of illustrator, light room and photoshop have been fixed and the menu's appear normal. Hope this helps.
2016-01-08T19:50:58+00:00 Hi Salman. Thanks for your reply! But my Adobe is in fact the newest version so how come? And do you know how it is possible that only Indesign is normal?
2016-01-08T20:08:22+00:00 I'm using Photoshop CC and the resolution seems to be good.. Is your Indesign the same version? I'm thinking the interface may be using the windows native buttons rather than Adobe's in that specific application.. Any how there is a thread soon where about changing the resolution within photoshop and other Adobe applications.. I'll see if I can find it. But I thought that feature was removed in the newer versions.
2016-01-08T21:24:54+00:00 I'm using Photoshop CC and the resolution seems to be good.. Is your Indesign the same version? I'm thinking the interface may be using the windows native buttons rather than Adobe's in that specific application.. Any how there is a thread soon where about changing the resolution within photoshop and other Adobe applications.. I'll see if I can find it. But I thought that feature was removed in the newer versions.
And that's what makes this issue so annoying and interesting, as some programs are fine but then others are way too small, it's just so super picky. As for changing the resolution, text size, try going into preferences/options, look for view or something like that, and look for "change text size", I was able to barely increase text size in a program that's way too small. As for resolution, right click on the desktop icon, and click on Compatibility, you can change the resolution there, but this is going off a different program.
Also, try getting in touch w/ MS support via the links posted earlier so we can get this problem even more heard.
