Print Spooler error 0x800706b9 printer not enough resources
2015-02-09T04:43:26+00:00
I have been trying to print for the past few day to no avail. I have gone to services and tried to manually start the stopped spooler, but this error keeps popping up. "0x800706b9 printer not enough resources". I am running windows 8.1 and I have a canon printer. I have already gone to the registry editor and got rid of the "http" in the spools folder. Please help...I desperately need to able to print.
2015-02-10T03:19:52+00:00
Hello Jason,
Thank you for posting your question on Microsoft community.
I would like to know some information about the issue so that we could help you better.
What is the make and model of your computer?
I appreciate you for providing details about the issue and your efforts towards resolving it.
This issue may occur if the installed device driver is corrupt or if the driver is not installed properly.
I would suggest you to try following methods and check if it helps.
Method 1:
Run printer troubleshooter and check. Please follow these steps:
a. Press Windows + W keys, type troubleshooting in the search box and press Enter.
b. Click "View all" and then click "Printer".
c. Click "Next" and follow on-screen instructions.
If it does not help, use method 2.
Method 2:
Please follow these steps and check the issue.
a. Press Windows + R keys, type services.msc in run window and press Enter.
b. In services, stop "Print Spooler" service.
c. In Windows explorer, navigate to the following folder location and open "PRINTERS" folder.
C:\Windows\system32\spool\PRINTERS
d. Click "Continue" or "Yes", if message prompts.
e. Delete all files in "PRINTERS" folder and then close Windows explorer.
Note: Please do not delete "PRINTERS" folder. Only delete its contents.
f. Open services, and start "Print Spooler" service.
I hope this information helps.
Please do let us know if you need any further assistance.
Thank you
40 additional answers
    2015-08-27T03:05:13+00:00
    Hello
    I have hp Envy 27 all in one as a desk top and HP office jet 8600 plus, I tried all that was suggested above, and have been with HP support for the past 4 hours, and they cleared the printer spool folder.
    I even tried uninstalling the printer, now I cant even install it back.  HP support suggested I contact Microsoft since it is a windows 8.1 issue
    please help
    2015-09-06T21:15:57+00:00
    Still not able to get printer to work.  I have the HP Officejet Pro 6830.  When I tried to install the "rebuild the print spooler file " I received this message,  " file is not a registry script.  You can only import binary registry files from within the registry editor.  Why can MS not fix this issue?
    Minor Cole
    Windows 8.1
    AMD A4-5000 APU with Radeon HD graphics  1.50 GHZ
    8.00 GB RAM
    64-bit OS, x64-based processor
    2015-09-09T21:10:25+00:00
    This did not work for me......I tried everything to the T
    2015-09-20T07:56:20+00:00
    try this.....I followed a hundred links and listen to multiple idiots....This worked for me
    Step 1. Press Windows key + R on your keyboard to open the Run prompt
    Step 2. Type "regedit" and hit Enter (this will open the Registry Editor)
    Step 3. Click the YES button to Confirm the UAC message
    Step 4. On the left Registry Editor, expand HKEY_LOCAL_MACHINE to find the following key SYSTEM\CurrentControlSet\Services\Spooler
    Step 5. While the Spooler key is highlighted, Click on the right pane to allocate the value DependOnService
    Step 6. Double-click DependOnService value to Modify it
    Step 7. The Value data field should contain the text saying RPCSS, followed by http in the next line
    Step 8. Select and delete the letters http and click OK button to save your changes
    Step 9. Close Windows registry and Restart your computer
    Step 10. Test your printing ability now
    microsoft, their partners and hundreds of links later.......all worthless...... I found this fix in a hp forum
